2001 Driveshaft into 1982 Camaro - Will it fit?
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
I'm gathering parts for a conversion. 700r4 or T56 into my 1982 Camaro Z. Right now it has a T350 tranny. I found a driveshaft from a 2001 Camaro that had a stick (sold ugh) but was wondering are the driveshafts same length for 4th gen and 3rd gen if converting same tranny? If I grab this will it work for either conversion?
Thank you.
Thank you.
Received 1,671 Likes
Re: 2001 Driveshaft into 1982 Camaro - Will it fit?
Yes.
Just be sure it isn't one of the ones with the cardboard (LITERALLY) stuffing inside of it, instead of any real balancing or damping.
Car: 1982 Z-28
Engine: 383
Thanks Sofa. Any way I can tell by pics? Or is there a code I need to look/ask for?
Car: 1982 Z-28
Engine: 383
Picked up a 1LE Aluminum driveshaft. Gonna replace the u joints. Do I need a conversion u joint or any stock replacement will work? Rear is a GM 10 bolt.
Also, can I use the U Joint straps I have now, or do I need to get new straps for the aluminum shaft? The u joints caps are close in size, 1/8 and 1/16, but don't want the u joints to slip out.
Thank you.
Thank you.
If the u-joints in it don't fit the 10-bolt pinion yoke, you need a conversion joint in back.
Once you have that, stock straps will work.
If you don't know what sizes you have, go through this and measure to identify yours: http://www.driveshaftspecialist.com/... ID Guide.html You will more than likely have either 1310 or 3R (S44 GM type) joints.
AmpleUnicorn88
Exterior Parts for Sale
11-26-2015 01:58 PM
camarochris89
11-01-2015 11:20 PM
