Transmission torque specs
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
I have a 1989 GTA with 5.7 350 engine and 700r Tranny what would be the torque specs for the oil pan bolts.
Received 1,664 Likes
Re: Transmission torque specs
Torque always goes with hardware size. Those being 1/4", they should get around 12 - 15 ft - lbs. The 4 corner ones being 5/16" should get more, maybe 22 or so.
But tightening them by torque isn't the best way to get a good long-lasting leak-free seal. Don't forget the most important thing, far more important than torque: straighten the pan at the bolt holes with your hammer, then bend them out backwards, so they make a little dome under the bolts. Then tighten the bolts until the pan is back straight and flat, and no more.
If you're talking about the trans pan, those are all 8mm, about the same size as 5/16", therefore should end up at somewhat near the same toque.
The pan bolts are all the same size. Torque to 65 - 75 inch pounds. Surfaces must be clean, and the pan flat. Duraprene gaskets are the best, and do not re-torque them. Make sure there is a magnet in the pan.
Car: Pontiac 89 GTA
Well my torque wrench starts at 120 Inch wich the box says that is 10 Ft Pound so I torke them at 120 Inch. Thanks every body for the advice.
a1rod
09-14-2019 07:38 PM
