Must i have a VSS for the TCC?
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Bought the car HACKED with a carb conversion. going back to oem TPI in my restoration. It has a cable speedo, no Vss located. Did the PO take it off? Or is this Stock. Its An 88 Iroc 5.7 700r
Thanks for any input..
1 Post
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: Must i have a VSS for the TCC?
The VSS is in the dash, behind the speedometer.
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
Cable speedo camaros have an electric VSS on the back of the cluster that feeds a signal to the ECM through the dash. It wasnt until 1990 that the VSS was moved to the tailhousing for all Fbodys
Wiring diagram here
https://www.thirdgen.org/forums/elec...cle-speed.html
Speedo backside pics here
https://www.thirdgen.org/forums/faq-...-fix-pics.html
kenney001
11-10-2015 05:27 PM
MikeCpa
11-03-2015 08:24 PM
