Can I use Prestone ATF in my transmission
Old 11-28-2015, 12:04 AM
'91CamaroRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 4 Speed Automatic
I don't have that portion of my owners manual that'd tell me what to use. I put Prestone ATF in it,but then a buddy told me I have to use Dexron in it after the fact. I admit it's stupid to ask this after I already did it,but I'd rather ask now than have to deal with a screwed up transmission.
Old 11-28-2015, 01:38 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: Can I use Prestone ATF in my transmission
ATF is not a type of fluid.. ATF just stands for automactic transmission fluid.
You need to know if the ATF you used is Type F, CJ, dexron/mercon, etc.
You need Dexron/mercon II, III, VI (all 3 can be used in chevy transmissions)
Old 11-28-2015, 01:15 PM
Car: 1991 Camaro RS
Engine: 305 TBI
It doesn't say. It just says its "multi-vehicle automatic transmission fluid+stop leak. Usable in European,Asian,and American cars."
Old 11-29-2015, 01:05 AM
Pro Built Automatics's Avatar
If the fluid has a "strong" chemical smell, this most likely is "seal swell". Depending on how much of this "seal swell" is added when the fluid was made, it can be destructive in the long run. If very little chemical smell to the fluid, you are probably ok. As mentioned Dexron type of fluid is best here.
1Aauto
Sponsored Vendors
11-30-2015 09:11 AM
carid
Sponsored Vendors
11-27-2015 07:08 AM
angelr
11-24-2015 02:53 PM
Hotrodder
11-15-2015 01:04 PM
Mirror Image
11-12-2015 06:09 PM
Quick Reply: Can I use Prestone ATF in my transmission
