S60 ls1 brakes question
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: strange s60 4th gen width - 3.73
Just got my s60 4th gen spec rear end and just wondering, am I going to have to do the backplates for an ls1 set up or can I get the calipers, pads, rotors and lines and call it a day or am I going to need a full swap kit like the one from FlyNBye.com?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: S60 ls1 brakes question
You will need the backing plates and E-brake cables too
Car: 91 Camaro RS
Engine: 305 TBI
http://flynbye.com/catalog/i60.html
This is the kit I'm looking at. The issue is, it's a Dana style rear end with no c-clips. Am I going to be able to use the stock backing plates off the 98-02 rear or do they need to be remachined to take the axle? The bolt pattern is the same as the small gm though.
SnkSknrZ28
06-02-2016 12:40 PM
dbrochard
23
02-20-2016 08:00 PM
joef2002
11-15-2015 12:02 PM
AmpleUnicorn88
Interior Parts Wanted
11-02-2015 09:33 PM
