Clutch Pedal wear
Clutch Pedal wear
Does anyone know of a fix for the worn stud on the clutch pedal where the clutch master cylinder attaches to the pedal? I welded mine up and it worked fine for a while, Im just thinking about drilling it out and cutting some threads to install a bolt and bushing. Has anyone else tried something that Im not thinking of that works?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Clutch Pedal wear
Remove the stud and use a bolt and nut
whyt86roc
01-16-2016 04:15 AM
