View Poll Results: Auburn or Yukon LSD
Auburn
0%
Yukon
100.00%
Voters: 3. You may not vote on this poll
Need help deciding LSD!
hey guys, i'm looking at getting a new LSD since mine wont lock up anymore. im between an Auburn:
http://www.summitracing.com/parts/au...model/firebird
and a Yukon:
http://www.summitracing.com/parts/yg...model/firebird
looking to see which you guys think is best. probably wont be till end of summer i can afford it but wan to get my research done now. thanks guys
and a Yukon:
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Need help deciding LSD!
Of the two, the Yukon
What about a Detroit trutrac?
even though the car isnt used for daily driving anymore. i dont want to get chirping or jumping around turns like i could get from a locker. the limited slip diff seems probably where i would look for this. could you find a part number or a link for the trutrac for these cars, i couldnt locate one.
There is no way that I would even consider the Auburn. If I were you I would remove it from the list of options.
The Yukon Dura Grip is an almost exact copy of the Eaton Posi. The main difference between them is the clutch material. I've installed several of the Yukon units and I have no complaints. The Eaton Truetrac is also a good option.
Also look at some of the new units from Power Trax. They have a copy of the Eaton Truetrac and a copy of the old Traction Lock.
Something else that you might want to consider is upgrading to 28 spline axles. This would be the time to do it. Instead of getting a 26 spline unit just get a 28 spline and a set of axles. Chances are that your axles need to be replaced anyway due to wear from the axle bearings.
28 spline axles are stronger, and you only have to replace the differential to upgrade. You are going to replace the differential anyway, so this is the time to upgrade. There is a good chance that your original axles are worn where the bearings run on them, so they would need to be replaced anyway.
its probably a good idea to just discard the idea of doing a locker, right? I'm still looking into the trutrack but its hard to find it for me for some reason. I am considering the axle replacement just because its only $250. summit just shows a set of moser axles, however they dont have good reviews. do you guys have any other suggestions? I'm not really well versed in the performance parts stuff
Tom's Differentials has high quality made in the USA axles that will fit and the price is good. He is probably the largest Eaton dealer in the world and has good prices on all of their products. He also has great installation kits and shims.
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
Get a used torsen out of a 99-02 Trans Am/SS, if you buy used you'll have saved enough to pick up some axles.
If you go that route make sure the unit is complete, they often are missing the center lock plate thing and its very hard to find.
1 Post
What do you mean ring & pinion job? You're going to have to set up the ring & pinion on the new carrier no mater what.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Since you have not filled out your profile below your user name.....
What gear ratio do you have in it now ?
dpmalibu
04-23-2016 03:59 PM
383backinblack
Brakes
04-18-2016 08:40 PM
[Sold] CompCams 987 Springs/Locks
MarkF
04-07-2016 01:55 PM
