9 bolt pinion shim
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
9 bolt pinion shim
I looked for a while, but I don't see many people (really anyone) talking about the pinion shims for the 9 bolt. I just took my old one apart and there was a shim under the cup for the head bearing and the housing. I messed it up good because I didn't realize it was there. Is this normal? I am used to the shim being between the pinion and the cone. I have been looking at "pinion shims" but no one has the spec, I am not opposed to calling Yukon, but it is the weekend and I am trying to get all the parts ordered for Monday morning.
Yukon has two listed ;
"55008 Pinion depth shims for GM 7.5", 7.75", 8.2" & 12 bolt truck
Pinion depth shims for GM 7.5", 7.625", 7.6 IFS, 7.6 IRS, 7.75", 8.2", 1955-1964 passenger car and 12 bolt car and truck"
and
"55064 Pinion depth shim kit for Toyota8", GM 7.5", 8.2" & 12 bolt truck
Pinion depth shim kit for Toyota 7.5", 8" and V6"
Anyone have any experience with the rebuild, or the correct P/N?
and
Re: 9 bolt pinion shim
I've removed the shims from behind the cup and put shims behind the bearing. It doesn't matter which place you put them, just as long as you get the depth correct. Many of the Dana rear ends also put the shims behind the cup.
Car: 92 Firebird
Engine: 4.8 LR4
That may make things easier. Are 10 bolt shims about the right size to do that with?
Car: 92 Firebird
Engine: 4.8 LR4
Oh, that's cool. Thank you for your continued support. I see you on several boards giving help.
Car: 92 Firebird
Engine: 4.8 LR4
I bought some pinion shims for the cone to side gear contact for a 10 bolt, as recomended by reading here and youtube and it looks like the pinion shims for a 10 bolt will work. The fit is a bit sloppy, the ID is too large, but it should work. I won't be making big power so it shouldn't matter too much, it's a stock V6 right now and I only plan on putting a stock (mostly) 4.8 LR4 in it in the future and I won't ever race it.
Unless you have another recommendation I will just order another set of those
Car: 92 Firebird
Engine: 4.8 LR4
Yeah, no worries, my memory sucks too. I tell people I have CRS all the time.
It looks like those 10 bolt shims will be perfect. If the ID was any tighter it would actually choke up on the radius behind the pinion-to-shaft transition anyway, so I will just roll with them.
Thanks for the help
Thanks for the help
By the way, I have a youtube video on my experience rebuilding and shimming the 9 bolt posi if you're curious. Would be a good time to do it and prevent damage down the road when the cones bottom out. The information in it is as accurate as I could make it at the time, 9 bolt info is hard to come by and I've learned a few things since then.
Most importantly there is no generic shim for any gear ratio, the pinion head is etched with a number for the pinion depth. So you have to set up the pinion and check it with a tool like one made by T&D called a pinion depth checker. And this kinda stinks because you have to press the bearing on top of the shims on the pinion gear then install it and check the depth. However there are two methods that can make this easier.
1) hone a new pinion bearing inner race that way it will slide on the pinion shaft bearing journal ” this bearing is only used for setup”
check the depth and of your shimming and if it meets the number etched on the pinion head disassemble the pinion and assemble the pinion with new bearing and install into the rear end
or
2)shim under the pinion bearing outer race into the diff housing” this is the most likely place you’ll find the original shims installed in the first place.
or
Why yes I did. I have nothing else to do except for contributing some value to this forum
fbodyman
07-09-2014 06:56 AM
