T5 VSS options...
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
T5 VSS options...
I have a 91 with a T5 and a leak coming out from where the VSS is mounted. I suspect its as a result of the O-ring on the VSS.
I have been looking and have not seen just the o-ring available..has anyone else had the same experience? what did you do - have to swap the whole sensor (mine works fine), or were you able to find a new o-ring or RTV it or something else??
Looking for some advise.
DK
DK
Car: 1990 & 1991 Firebird Formula 350's
Engine: 350 ci
Transmission: T 5 & 700r4
Axle/Gears: 3:23 & 3:27
Re: T5 VSS options...
just go to lowes or home depot and look in the plumbing section. you'll find something that will fit.
