Speedo gears and trans rebuild
Car: 91 GTA
Axle/Gears: 3:73
Can someone confirm my part numbers, it's a 700r4 matted to a 3:73 ring and pinion with factory 245/50/16
I have drive gear grey 8642620
Driven dark grey 9780470
Sleeve driven gear 25007339
I've been driving this car putting extra miles on it for no reason but procrastination
Car: 91 GTA
Axle/Gears: 3:73
Re: Speedo gears and trans rebuild
Recently got a fresh rebuild on my 700r4. I asked the shop to replace the drive and driven gears for the speedo but they never did.
Do I need to drop the tail housing?
Is there fluid inside this housing?
I'm assuming yes to both of these questions.
Really wish the shop replaced these gears as I even provided part numbers
There is a small amount of fluid in the tail housing.
Not sure on your part number I think it should be 8 digits for 89-92.
http://m.ebay.com/itm/44-tooth-700r4...%257Ciid%253A1
25513051 44 Dk Gray 25007339
standard motor products sc13 vss
http://m.ebay.com/itm/Speedometer-Dr...%257Ciid%253A3
Car: 91 GTA
Axle/Gears: 3:73
Thanks for the confirmation on the 15/44
Just wondering if i need 3 different parts:
1. 44 tooth
2. 15 tooth
3. Sleeve driven gear 25007339 ? I made this post awhile back and can't find info what pointed me to this part. What does it do?
Can I just use the 15/44?
1. 44 tooth
2. 15 tooth
Car: 91 GTA
Axle/Gears: 3:73
1988_f-bird
03-15-2016 01:06 AM
Stang Eater
Aftermarket Product Review
04-11-2001 12:05 AM
