T5 help
T5 help
I have a 86 ta t5 wc and a mild built 350 pushing it and it does great until about 3,500-3,700 rpm it stops accelerating but the rpm still go to 6k and just smokes the clutch what's the problem
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: T5 help
Pressure plate is worn out, or not strong enough.
Received 1,664 Likes
Re: T5 help
Gears don't "limit out".
Neither do RPMs. (unless done deliberately)
Sounds like you need a clutch.
Doesn't too much matter what's in it now; it's toast. Sounds like a normal stock replacement ought to be just fine.
Car: 1992 Camaro RS
Re: T5 help
Stock replacement should be fine as Sofa suggested. I'd add a flywheel to the list too. Yours is probably burnt.
Re: T5 help
"Better", depends on the circumstances.
Remember: sayings like "product meets expectations" requires 2 things to be evaluated: both "product", AND "expectations".
I'm not seeing where either of those drivers of decision making require any of the above.
If your flywheel is compromised, get the one for L69/LB9 cars, with whichever crank bolt pattern your motor has. (86 was the changeover year, but it'll be a function of your "mild" 350 and what block it's built out of, NOT the wrinkles in your sheet metal) Those are the "lightweight" stock ones, which is all you'll need. A stock clutch should be fine.
Don't outsmart yourself with a bunch of "race" parts that don't match the rest of the program.
Re: T5 help
The best thing you can do now is take it apart and see what failed and how it looks. Post some pictures and then decide what you need.
330hp_91RS
03-11-2003 02:50 PM
Andy Fanshawe
10-14-2002 03:26 PM
1983Z28
04-21-2001 01:16 PM
