Grinding noise felt in gas pedal???
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Axle/Gears: 3.42 10 bolt
Like the title says, I heard a grinding noise when launching (as much as I can without a posi) my car on the street, but I could feel the vibaration in the gas pedal. It happened a year and approx. 2500 miles ago but hadn't reoccurred again until yesterday. The noise came from the front/bottom of the car. I don't know if this matters but the transmission doesn't have a flywheel cover. If anybody has a clue I'd appreciate it.
Car: 1985 camaro z28
Engine: 283 chevy
Re: Grinding noise felt in gas pedal???
I just had this problem occur Sunday. Someone told me that it may be the flywheel or starter. Maybe thats something that we could start with.
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
Were you accelerating hard? Something tells me its transmission related, maybe I'll do a flush this weekend and see if there's crap in it.
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
I'll check those once I can get it on the lift. My brother's mustang is on it now...
Car: 1985 Camaro
Engine: 5.3
Transmission: 4L80e
I found the cause, it turns out my transmission mount is cracked pretty bad and the u joint would hit the exhaust heat shield and floorpan during acceleration.
