TH350 transmission mount for the IROC-Z
Car: 1986 Iroc-Z
Engine: Carbed 350
Transmission: TH350
Hi what transmission mount do i need to mount my TH350 correctly in my IROC-Z with the stock transmission crossmember?
Thank you guys.
Currently i have this mess on my car Its just a piece of rubber stuck in there, transmission jumps all over the place.
Thank you guys.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: TH350 transmission mount for the IROC-Z
The mount is not the problem its the crossmember.
UMI, bmr, Spohn ECT all sell crossmembers to mount your trans.
There is a factory one that works too if you can find one from an early car. Uses the extra set of untapped hole in the subframe just ahead of the ones your using now.
3rdgenparts
10-13-2016 06:41 PM
