How can I soften my shift kit?
Hello everyone I bought an 89 Camaro a while ago and it had a shift kit already in it. It wasn't so bad as 1-2 is really hard but the rest are good so I was just letting off the gas from 1-2 and it was good.
However it's pretty annoying to constantly do so I'm wondering if there's a way to soften the 1-2 shift? It's so hard the tires brake lose it caused the car to slide out a couple weeks ago. It also shifts super heard from park or neutral to reverse or drive I saw the tires actually spin when it shifted.
Im most likely going to do a flush again as it had some very thin clear fluid in it and it ruined the first flush. So if I have to take the pan off its not a big deal but is there anything i can do to soften these shifts?
Engine: 4++,350 & 305 CIs
Re: How can I soften my shift kit?
Put a stall converter in it
It only takes me about 2 hrs to R&R a automatic
Car: check
Engine: check
Transmission: check
While the pan is down check the 2nd accumulator. It may be that the spring broke or that it is blocked. Easy fix if so.
RBob.
RBob.
