Cam/Stall question
Old 10-18-2016, 02:31 PM
edixon24's Avatar
Car: 1990 IROC
Engine: 383 Trickflow HSR
Transmission: auto
Cam/Stall question
Im almost done with my 383 build. It will be a daily driver. the cam I went with has an rpm range of 2500-6000. My highway cruising speed is about 2500 rpm. Ive heard that you want a stall speed of aroundt 400 rpm higher than starting range of your cam but no higher than highway cruising speed. so... which is more important and will I hurt anything by going with say a.... 2000 stall? any recommendations other than that? 1990 IROC 700r4 trans 3.27 gears. I know everyone is going to tell me to get different gears but Id rather avoid that for now
Old 10-18-2016, 03:43 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Cam/Stall question
Post more info, exactly what cam and what parts are in your engine.
Old 10-18-2016, 03:50 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
2000 stall is barely a stall at all. 2400-2800 is good for a street build. With what you have described loosely id say 2800 would be better suited. 327 isn't a bad gear with a 700R4 because the 1-2 shift is pretty good in that tranny.
Old 10-18-2016, 03:52 PM
edixon24's Avatar
Car: 1990 IROC
Transmission: auto
https://www.summitracing.com/parts/cca-08-433-8 is the cam
trick flow super 23 195cc heads
eagle performance 383 rotating assembly
10.5:1ish CR
1.5 roller rockers
stock transmission and rear end
Old 10-18-2016, 03:53 PM
edixon24's Avatar
Car: 1990 IROC
Transmission: auto
oh and I went holley stealth ram with accel 32# injectors
Old 10-18-2016, 03:55 PM
edixon24's Avatar
Car: 1990 IROC
Transmission: auto
so my highway cruising RPMs... not a big deal to have the stall speed higher than that?
Old 10-18-2016, 04:57 PM
bk2life's Avatar
Car: 91
Engine: 5.7
Transmission: 700
if you get a 'lock-up' converter it wont matter what your cruise RPMs are, as the converter will lock and be 1:1.
most factory late model vehicles have nearly a 2k stall stock. if it were me, i would get an advertised 3k stall. BUT---stall RPMS change with torque, heat, and quality.
Old 10-18-2016, 06:01 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: 383-Holley Terminator EFI
Transmission: 700R4 Pro-Built Street/Strip kit
Axle/Gears: Strange S60 3.55:1
Call Dana at Probuilt Automatics
https://www.700r4l60e.com
I bought my converter from him, great guy and full of wisdom. He's going to ask you for cam, intake, head, and other engine specs so be prepared with all of that upfront.
Old 10-18-2016, 06:09 PM
edixon24's Avatar
Car: 1990 IROC
Transmission: auto
what would happen if I left the stock converter in with that setup?
Old 10-18-2016, 07:00 PM
Lurbie's Avatar
Car: 89 Camaro
It's like the difference between starting out in 3rd gear vs starting out in 1st gear.
ASE doc
09-22-2020 12:50 AM
Wph351
LSX and LTX Parts
02-15-2017 06:35 AM
BovineZro
08-28-2016 06:19 PM
pos88transam
08-16-2016 08:16 PM
thewizard
08-06-2016 09:30 AM
Quick Reply: Cam/Stall question
