T56 noise?
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
T56 noise?
I think my t56 is making a loud noise. It sounds like a gear or bearing whine when driving it, kinda like if the rear end was not set up properly, but sounds like the trans. However, I cant tell if its the rear end or t56. It gets worse when its hot, gets a little hard to get into the gears after any sort of abuse.
at idle I can hear the bearings in it kinda very lightly "hissing". Its been doing it for a while, so I doubt its catastrophic, but this winter, I'm going to remove it and take it apart.
Its a very low mile transmission. It was removed from a new camaro for a warranty issue back in the early 2000s. Sat on the shelf for many years, then ended up in my car back in 08 since I couldn't find anything wrong with it. No idea why it was removed originally, but I'm guessing it was this.
Is there any common issues on the t56 that would cause them to make a whine noise?
Re: T56 noise?
Check fluid level
Does it come and go when you press the clutch?
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: T56 noise?
The noise at idle is very faint, more like a moving parts noise with clutch out in neutral. Whines when its moving clutch in or clutch out.
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: T56 noise?
Input shaft
Cluster gears.
Well I pulled it today. Depending on what I find will determine whether I part the car out or not. So far It doesn't appear to have much wear, or at least no signs of an obvious problem.
