Speed sensor for 2004R with with 7730 TPI
I abandoned the 4L80E swap (won't go into all the details)...
But I'm now looking at a built 2004R as an alternative to going back to the 700R4 and that stupidly huge spread between 1st and 2nd gear.
I can get a complete 2004R set up (converter and everythign else) for $2400 from Bowtie Overdrives, capable of handling any future 427 sbc I hook up to it.
Question is, what speed sensor do I need to run in order to be compatible with the 7730 TPI system I'm running?
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: Speed sensor for 2004R with with 7730 TPI
Don't know if this helps but: https://www.thirdgen.org/forums/tran...p-finding.html
It may be available local so you would need to see if it would work. My understanding is that the "bullet" is a different size than other 350, 700r4 or T5 "bullet" so special to the 2004R? HTH!
