T56 swap crossmember issue
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Got the crossmember in a trade. Seems it's two inches too long. Is this for a different t56?
1 Post
Car: 87 firebird 86 c10 90 mustang
Engine: 383 sbc
Transmission: 97 t56
Axle/Gears: Moser 12 bolt 3.73
Re: T56 swap crossmember issue
The borg warner i think is 1 1/2 inch shorter then the tremic, which one do you have?
Car: 91 Camaro RS
Borg warner. However we cut a plate from 1/4 steel and mounted it between the two. Works great
There are three sets of crossmember holes on 83-92 third gens I believe. I don't recall if the front two might be able to be used.
As for LS /LT, the LS bellhousing is about 16mm deeper, the rest of the trans. is the same. The distance you're dealing with is greater than that amount.
Car: 91 Camaro RS
If you don't mind can you post pics of what you did? Thanks
Who makes that crossmember? Check out this thread for pictures. See if it helps. You may have the wrong crossmember. And I wouldnt do the plate you are talking about. It will raise the angle of the driveline which will throw off the pinion angle. For the cost of a new crossmember, Id just buy a new one and be done with it.
https://www.thirdgen.org/forums/tran...ong-tubes.html
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
I believe I have this same cross member. What are my options and what cross member is this?? I have the same issue right now with my swap. My trans mount won't line up.
