changing the flexplate
Old 03-07-2002, 01:29 PM
Grizz's Avatar
How hard is it to change the flexplate on a 700r4? would i have to pull the tranny all the way out, or could i just slide it back a tad? how long would this take? thanks--Dustin
Old 03-13-2002, 01:34 AM
BigH's Avatar
Flexplate change
Gizz,
I think it is easier to pull tranny almost completely out. The issue will be how hard the bolts are torqued. You will need a way to prevent the crank from turning as you remove the flexplate bolts. Red thread lock is essential.
Old 03-13-2002, 04:08 AM
ronterry's Avatar
Car: '94 Corvette
A good long 11/16 wrench for the crank bolts, and a flexplate tool(get it at your local Checker Auto) to hold the flex from turning.
You'll still need to remove the driveshaft, crossmember, and oil lines on either the radiator or trans.
I actualy used very long 3/8 bolts (put in place of the lower mounting bolts) to guide the trannie back, without losing alignment. I also used a trannie jack !!!
Set aside 2 to 4 hours with a good lower back, or 8 hours for a back like mine.
Ron
84z96L31vortec
08-20-2017 12:16 AM
BAMiller
09-14-2015 06:38 PM
z28guy134
09-01-2015 11:50 PM
84z96L31vortec
08-10-2015 08:27 PM
gwade12
08-08-2015 08:17 AM
Quick Reply: changing the flexplate
