help with the next step
ok guy's can you help me out with the next step
i have a 91 bird with the 3.1l
this is what i've done so far......
the complete tune up msd cables with the made for you clips and a hose dress up kit
dynomax exhaust w/ hiflow cat I'm still waiting for the
GenerationX header's i've ordered from Camar_Hunter_c
kyb's shocks and struts & oem springs ( i think i'm going to end up lowering it after all
wonderbar and ws6 sway bars i'll have in a few weeks from lonsal with topdownsoultions
a complete energy suspension hyperflex kit
ok now as for the next step.......
with luck next month the motor will be comming out for with luck the headers es kit and sway & wonderbar's and at that point i would love to have everything else done as well.....
what would you guy's recomend i'm looking for anything and everything that will help with power & performance..........
if you have any catalog number's and or prices it would be a big help........
step three will be the stb and sfc i'm still not sure what company i'll be going with then after that i'll be heading into the body shop............... still have not pickec out a color yet either
well thanks again
well thanks again
See if I could do anything I would build a stronger bottom end, waste money on forged pistons and pour 150HP of nos into it… Along with that I would custom make a sheet metal intake with a V8 Throttle Body. More realistically I want to:
Get the heads shaved to raise compression
Gasket Match and Polish the Heads
Run 105# Valve Springs and 1.52 Roller Tips
New Crane 2030 Cam
68MM Throttle Body (Would need to be custom)
Extrude Hone the Upper and Lower Plenum (I mean make it thin)
2800 RPM Stall Converter
3.73 Posi setup
Tubular Lower Control Arms
Tubular Pan Hard Rod
Tubular Torque Arm
Sub Frame Connectors
New Crane 2030 Cam
3.73 Posi setup
Tubular Torque Arm
lol
hummmmm
i had a funny feeling you were going to ask me that Tom
i just want to give the bay a total cleaning repair a few rust spots
and give it a good painting..........
so far i'm thinking about maybe
new cam *
new pully's
roller rockers *
ignition
roller chain
as for the intake i'm really not sure weather i want a ram or cld setup if go try for a ram i really would liek the hood
what else should i look at or posibaly consider
( * what do these part do )
new cam *
new pully's
roller rockers *
ignition
roller chain
Car: 1986 Firebird
Engine: 2.8 V6
Haha, okay, cool, I was hoping you weren't going to pull it for a suspension rebuild! I agree w/Brian on the http://www.por-15.com stuff... you could probably make due with the Super Starter Kit for $20. I used it on my 3.73/posi/disc axle, and it was just enough to give the axle two coats. Don't buy much more por-15 than you need; the stuff starts to dry the second you expose it to air. (It's more of a chemical than a paint, it absorbs humidity, and that's how it "dries".) If you think you need more por-15 than the super starter kit comes with, consider buying their 6-pack of por-15. Then you won't wind up with a gallon sized can that's all dried up after a month!
Gunner242
12-25-2015 04:49 PM
Chad Speier
09-24-2015 12:32 PM
