Vaccum hoses
Vaccum hoses
I recently had to swap motors in my 86 V6 Camaro. I worked on it over many weeks and have now forgotten where a the lines go. If anyone has a diagram or knows what goes where and where from please let me know.
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Welcome to the board.
Where abouts in canada are you from.
On the under side of your hood there should be a diagram.
GO TO ANY GM DEALER
Ask parts guy to pull up the exploded illustrated of PCV hose routing diagram of your model year engine & car.
MAKE SURE you also get a print out of the parts with part numbers.
Give him a soda!
BIGGEST PROBLEM
USE 5/16" windshield wiper hose to patch the broken hard plastic lines
No parts are available anymore.
You can rebuild as most of the lines will literally fall into place.
The EGR is the MOST DELICATE
Make sure you don't screw up the diameter of the hoses.
THE EGR HOSES SECTION MELTS keep awway from heat sources by zip ties.
I spent one whole day on my hose patching for my swaps.
AND I also revisited several times.
1/2" heater hose short length at base of the distributor driver side area is a bastard.
Ya can solve it!
Give him a soda!
BIGGEST PROBLEM
Ya can solve it!
Pac J
05-17-2020 10:44 AM
2012sergen11
10-13-2015 07:38 PM
