Strong gasoline smell from exhaust
Old 03-01-2005, 03:05 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
I've noticed this lately,whenever I rev my engine or its idling in the morning warming up.A really strong smell of gasoline comes out.I could almost swear its pure gasoline.There's no actual gas coming out of the exhaust.I'm not getting a SES light.The car is a 91 Firebird with Dynomax Exhaust.
What could be the problem?
Old 03-01-2005, 08:18 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
check for pin holes in the fuel lines. has your fuel economy gone down too?
Old 03-01-2005, 09:44 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Fuel economy is horrible.How can I get holes in my fuel lines.Wouldent it leak then?
I never notice any fuel leaks.
Old 03-01-2005, 11:24 PM
Engine: 5.7 / 7.4
my lines running along the front frame rail were rusting. I had a nice fun time replacing them.
Old 03-01-2005, 11:34 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
you ARE smelling pure hydrocarbons and you say that you smell it when you rev or when idling curing warmup, right? Well, the most likely case is that your CAT is dead and you are smelling what normally comes out the end of our cars. the times that you are describing is when the engine is open loop. My CAT is completely hollow and and I have the same symptoms that you're decribing, the poor milage is probably unrealated to this, but then it again, it could be. Do you have any other symptoms like hesitation, bogging, overheating, pinging, bucking or surging, or anything like that?
Do you smell it when you are idling AFTER warm up?
Old 03-02-2005, 01:34 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
My car does hesitate like 1/6 times I "get on the gas".
I dont have any other symptoms like overheating or pinging but yes I do smell it after warmup,just not as strong.
Old 03-02-2005, 11:02 PM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
yeah man, i have those problems. its a 91, 3.1 like yours. i can smell it inside too. i get like 230 out of a tank. i smell it at red lights. it sucks man. but...my cat should be good. i passed emissions 5 months ago, when it smelled like that, fine. mines under the hood though. can u smell it under the hood?
Old 03-02-2005, 11:04 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Mine passed emissions about a year ago with awesome results.I can also smell it at a redlight and inside the car,not under the hood though.Ill be lucky if I get 200 per tank....
Old 03-03-2005, 02:54 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
thats terrible gas milage. as well as hesitating, theres a problem
you may be running rich, say timing might be off, or a sensor dumping too much fuel... or you may have a hole in the tank or line...
Old 03-03-2005, 11:58 AM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
But yet theres no SES light.
Old 03-03-2005, 01:17 PM
Car: IROC Z
Engine: 5.7
timing wont throw a code
Old 03-03-2005, 01:56 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Next time I go to get an oil change ill ask them to check the timing...Should it cost extra?
What should the timing be set at?
Old 03-03-2005, 03:16 PM
Car: IROC Z
Engine: 5.7
depends on where you get your oil change at. i dont think people at quickie lube places would know how.
Old 03-03-2005, 03:54 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Goodyear?
Old 03-03-2005, 03:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Buy one of these http://www.harborfreight.com/cpi/cta...temnumber=3343 and check it yourself!
Old 03-03-2005, 04:00 PM
Car: IROC Z
Engine: 5.7
wow i had no idea they were that cheap. i bet they would charge you 20$ to have it checked
Old 03-03-2005, 04:01 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
I wish it was that simple and I could do it myself.....
Old 03-03-2005, 08:51 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
that's because that is a crappy light. It doesn't have any advance or RPM functions. Unfortuantly, wiht tools, you pretty much get what you pay for. If you're just a backyard mechanic and don't plan to be really using it that often, sure, by all means, buy this one. But I do not recommend it if you plan on using on multiple cars because most cars simply have a needle and a mark on the pully.
anyway, back to the original post...a hesitation is USUALLY caused by a lean condition. that could also make you smell the gassy exhaust because you have a slight lean misfire. it'll do the same thing as being rich, but if you were so rich that you were hesitating because of flooding, then you would get puffs of black smoke. Things to check from here: O2 sensor, TPS and Fuel Pressure. If you like, you can buy a tool from some places that plugs into the injector harness, then you turn the key to "on" then hit the button on the tool. It pulses the injector for a pre-determined amount of time and you get a list of common pressure drops in the fuel system. That'll tell you if you have any bad injectors and you can do it without having the car running, which is a good thing because in order to reach the injectors, you have to remove the upper plenum.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
Twin_Turbo
03-14-2016 10:10 PM
earlpote
09-12-2015 11:55 AM
Glowsock
09-11-2015 11:09 PM
Blue419
09-10-2015 01:03 PM
Quick Reply: Strong gasoline smell from exhaust
