HOW TO: INSTALLING A TURBO
#202
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: HOW TO: INSTALLING A TURBO
Tunerpro is a great program, easy to use IMO if you want to keep your stock ecm
#204
much better off just swaping in a fuel injected v6 first since the carbed v6 has a weaker crank in it
#206
Car: 1987 pontiac firebird
Engine: 2.8L v6
What do you do with the vacuum lines? will it work if leave them how they are stock and will the brake booster still work? will i to have to doo any tuning to the ecu if i am only running 7psi of boost and it looks like you changed the o2 sensor, can i use the stock one?
#207
As for the vacuum lines, use check valves where and whenever needed.
- Rob
