after market parts for 60* motors
Old 08-06-2007, 07:44 PM
  #51
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: after market parts for 60* motors
that picture is out of an extended cab s10. There was no holdback on the funds, he spent like 700 just on rockers IIRC.
Old 08-06-2007, 08:20 PM
  #52
firstfirebird's Avatar
So many people fall into the expesive mods. I'm using 1.7 roller tips on LS6 springs, 3500 heads, custom cam, 75mm TB, ported on a 3.4. hoping to see 225 N/A (for less than $1k)
91Convert, go to the V6 forum and look at the top for a "new thread" icon. Also if you would be interested in an Eaton M90 bolt on kit, PM me.
This thread is supposed to be for 60* performance parts
Old 08-06-2007, 09:52 PM
  #53
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
well that Fageol will work on the carb'd 2.8's as well.. its in the intstrunction manual of the one I own on how to set it up properly.. I think we should start a forum on how many people would be interested for a company like edelbrock to make a new FI manifold for us.. Im sure if there was enough interest theyd do it..
Old 08-24-2007, 12:34 PM
  #54
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
UD pullies, 60/62mm TB, engine dressup:
http://mrzperformance.vstore.ca/inde...cPath/23_24_31
Old 09-23-2007, 01:14 PM
  #55
PedalToMetal's Avatar
Do the computer chips for the 89 work for an 88 too?
Old 09-23-2007, 11:15 PM
  #56
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Depends on what you mean, but aftermarket chips made for an '89 should work on an '88.
Old 09-25-2007, 05:08 PM
  #57
Hell yeah, thanks. Do i have to change something if i buy the stage 2 JET chip? I mean apart from a tuner. Will it work good on a stock car?
Old 09-28-2007, 08:52 PM
  #58
bl85c's Avatar
Car: '85 maro
Works fine on a stock car. Your money would be better spent getting the equipment to tune it yourself though.
Old 10-02-2007, 03:16 PM
  #59
bl85c's Avatar
Car: '85 maro
Here's a list of what we have so far. Note that I have omitted certain components not specifically related to the 60deg v6 or that are listed as replacement parts which may be compatible.
Chips-
Jet stage 1 chip> 18908
Jet stage 2 chip> 18908S
Hypertech chip> 129322
Hypertech chip> 128932
Engine components-
GM performance parts alumium block> 10051141
Probe forged pistons (at fiero store)> 52833
Probe forged pistons (at fiero store)> 52835
ARP rod bolts> 133-6002
ARP head studs> 233-4003
ATI harmonic balancer> 917190
Melling high volume oil pump> M95HV
Sealed power high volume oil pump> 224-4148V
Sealed power high volume oil pump> 224-4152V
Edelbrock chrome valvecovers> 4488
Spectre chrome valvecovers> 5268
Headers-
Pacesetter headers> 72C1206
Pacesetter headers> 70-1206
Ignition-
Mallory mechanical distributor> 4569201
Mallory mechanical/vacuum distributor> 2769201
Proform mechanical/vacuum HEI distributor> 67082
MSD cap & rotor kit> 8430
Accel cap & rotor kit> 8133
Mallory rotor> 331
MSD HEI coil> 8226
Proform HEI coil > 66937C
Crane ignition box & coil kit> 6000-6302
Pertronix HEI ignition control module> D2000
Accel HEI ignition control module> 35361
Induction & fuel-
NOS 3.4/3.8 nitrous kit> 05175NOS
(most generic carbs compatible with use of edelbrock 3789 upper intake manifold)
Edelbrock intake manifold (upper 2bbl)> 3787
Edelbrock intake manifold (upper 4bbl)> 3789
Edelbrock intake manifold (lower)> 3785
(most generic injectors compatible)
Underdrive pulleys-
Auto specialties pulley kit> 541801
Jet pulley kit> 90108
Valvetrain-
Edlebrock cam & lifter kit> 3790
Comp cam> 16-233-4
Comp cam> 16-232-4
Comp cam> 16-115-4
Crane cam> 250511
Crane cam> 250801
Crane cam> 251241
Crane cam> 253901
Crane cam> 253941
Crane cam> 254112
Crane cam> 254122
Lunati cam> 06312
Melling cam> MTC-5
(most sm block v8 lifters compatible)
Comp roller tip rockers> 1414-1
Crane alum roller rocker (single)> 25750-1
(most sm block v8 rockers compatible with use of 3/8" or 7/16" studs)
Cloyes roller timing chain> 9-3137
(most sm block v8 and LS1 valve springs compatible with use of associated hardware and/or spring pocket machining)
Links-
www.kb-silvolite.com > large resource for replacement pistons
www.60degreeev6.com/store > ported cylinder heads/ intake manifolds/ throttle bodies, crank scrapers, ect.
www.fierostore.com > ported cylinder heads/ throttle bodies, forged pistons, ect.
www.engine-parts.com > stroker kits, shortblocks, cams
mrzperformance.vstore.ca > ported throttle bodies, underdrive pulleys, billet oil caps
Old 10-26-2007, 01:06 AM
  #60
91convert's Avatar
Does anyone know if those pacesetter headers (that fit the 85-90) will fit my 1991 3.1?
Old 10-26-2007, 08:36 AM
  #61
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
yes that will
Old 12-17-2007, 01:06 PM
  #62
epic612's Avatar
Car: 1989 Firebird
Engine: 3.1L MPFI V6
Transmission: automatic
Originally Posted by TomP
Sogabe, actually, most of that stuff works for you too- except an intake. Don't forget us 2.8 MPFI guys don't have an intake either. A carb'd intake is only for 82-84 models. That's part of the fuel-injected 2.8/3.1 "curse"... no intakes.
DrDave88, thanks for the poly mount link! Have you used their products on an f-body? I had heard that the 4.3 V6 poly motor mounts were the same as V8 mounts; will they really work on 2.8 f-bodies?
wait, there is no cold air intakes for the 2.8? damnit.
Old 12-17-2007, 06:29 PM
  #63
bl85c's Avatar
Car: '85 maro
The 2.8 camaros don't need an 'intake'. The stock air filter flows more than enough and draws infront of the radiator so it's already a 'cold air' intake. You can cut a hole below the firebird air filter canister to turn it into a cold air setup.
Old 12-17-2007, 11:08 PM
  #64
epic612's Avatar
Car: 1989 Firebird
not the camaro. i'm rockin the bird. but i want to eventually, over time, to a total overhaul on the car, and one of the things was to install a cold air induction.
so you're saying i don't need it? but if i still wanted it, ya know, for the look and all, where could i find one? or am i **** out of luck?
Old 01-02-2008, 08:06 PM
  #65
bl85c's Avatar
Car: '85 maro
Late reply, but anyway you really don't need to change the intake setup unless you plan on some serious mods, but if you just want a cold air setup you can cut a hole below the air cleaner. I don't know of any aftermarket intake setups for the 2.8 or 3.1.
Old 01-05-2008, 08:01 AM
  #66
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
there arent any aftermarket ones available for the firebird, but plenty of people have made them, do a search and im sure youll find plenty of pics and some details on how to make one.
Old 01-11-2008, 06:56 PM
  #67
backgammon7's Avatar
Car: '86 SC
Engine: 2.8
were can i get an intake minifold for a fuely 2.8
Old 01-11-2008, 07:20 PM
  #68
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
The only aftermarket intakes are for the carbed motors, you can port the FI intakes. The only other intake that will work for the fuel injected motors is the FWD ones but that involves a whole topend swap which would give the best results, much better than out top end.
Old 01-11-2008, 09:56 PM
  #69
bl85c's Avatar
Car: '85 maro
Actually you could get the carb manifold from edelbrock, but a 3x00 top end swap would be almoast as involved and give much better results.
Old 01-11-2008, 10:21 PM
  #70
Carb to Gen3 is not that easy of a swap.
Remember the 2.8/3.1's don't have a way to get the crank signal to the ECM, and the exhaust manifolds won't work (even headers need some modification).
Old 01-11-2008, 10:25 PM
  #71
Six_Shooter's Avatar
Transmission: 5-speed/T-5
If you REALLY want an aftermarket intake for the iron heads, look up "Potter race heads" or "Potter Racing", something along those lines. AFAIK they are not making the genI 660 intak emanifold, but you may be able to find one for sale somewhere. About 3 years ago, Potter cleared out ALL of thier 660 parts, even the prototype stuff in a single lot, there was some pretty interesting things in that lot.
Old 01-11-2008, 10:34 PM
  #72
bl85c's Avatar
Car: '85 maro
Both are pretty involved swaps (although you and I want to make it seem easy ) but with a little more work and some creativity a much better fi setup can be had.
Old 02-17-2008, 05:51 PM
  #73
thirdgenfcarnut's Avatar
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Axle/Gears: stock 3.23
Hey great list. I am glad to finally find 60* f body enthusiasts. When I called Summit, they told me none of these parts were available!! WTF!! The headers you listed state they are only for the 2.8 I have a 92 RS with the stock 3.1 Will these fit my motor? Do they have an EGR provision? If so, I am assuming it is for the vacuum controlled egr, not the electronic controlled soleniod like mine? Thanks!
Old 02-17-2008, 06:25 PM
  #74
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
The headers will fit. You will just have to toss the AIR pump and the EGR can be put back on.
Old 03-11-2008, 11:40 PM
  #75
87InRecovery's Avatar
Car: '87 Camaro Sport
Engine: 3.4L w/headers, Crower & Hypertech
Transmission: 700R4, B&M Shift Kit
Axle/Gears: ?
OK guys, I am new to the forum since my $350 '87 Ebay purchase last summer. I brought it back to life, and have been in desperate search for performance upgrades.
Well Gentlemen, I have a good addition to this forum for internal components.
CROWER
Just go to http://www.crower.com/misc/m_cat.shtml which should be there main catalog. Page 18 or 19 lists hydraulic and solid cams and lifters, etc... for a reasonable price.
They sell all internal components, even if they have to be custom. A lot is already in stock, however some items such as connecting rods just say Chevy V-6. They list the measurements, however I don't have any information on the '87 2.8L connecting rod specs. My manual doesn't cover those lengths and diameters. A shop manual will be in my immediate future purchases.
By the way, Accel makes the Fuel Injectors from 17lbs. on up for this engine. When purchasing a performance chip from Hypertech for example, do they list a specific fuel injector compatibility?
Old 03-14-2008, 09:01 AM
  #76
Axle/Gears: ?
MPFI Pistons
Gentlmen,
I am going to purchase some pistons soon. I haven't disassembled my engine yet, but am wondering if the stock pistons are flat top, dished, or have valve reliefs in them?
Also, what is everyone's thought about the oil ring. Do I NEED a piston with a "shallow oil ring groove"?
Old 03-14-2008, 01:30 PM
  #77
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Re: MPFI Pistons
Depends on what motor you have. The 2.8 pistons are flat tops and the 3.1 pistons are dished I believe.
Old 03-26-2008, 04:05 PM
  #78
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: aftermarket parts for 60* motors and v6 cars
Just thought Id point out that these are V8 springs. A recent post made me look at them. They still can work, but youll have to cut them down...thats kind of a waste of money to cut down such expensive springs.
Old 04-02-2008, 10:44 AM
  #79
grimmcs's Avatar
Car: 91 Camaro
I just wanted to add that I found the V6 lowering springs.
Suspension Techniques 60115
I think that the main list on page 1 should be updated with all the new parts and info.
Old 04-28-2008, 09:56 PM
  #80
camarofan90's Avatar
Car: 91 camaro
Engine: 3.1 v-6
does anyone know if their is and were to find a "fordged steel rotery set" i think that is how you spell it, for 91 3.1 v6 any help would be nice
Old 04-29-2008, 12:08 AM
  #81
Axle/Gears: ?
The only forged items I found (especially the crankshaft) are custom made by Crower and will cost a pretty penny.
Old 04-29-2008, 12:29 AM
  #82
project89's Avatar
i belibve i posted another link to a forged crank it ran 700$'s id have to go back threw the whole post and look though
Old 04-29-2008, 12:47 AM
  #83
A 3500 crank is forged and costs $400 to turn the rod journals down from 2.249" to 1.99"
(3500 crank in a Gen1 60*)
Old 04-29-2008, 11:28 AM
  #84
bl85c's Avatar
Car: '85 maro
The rods are forged from the factory and the fiero store has forged pistons.
Old 04-29-2008, 12:46 PM
  #85
project89's Avatar
whats a sbc rod journal again?
edit nm its 2.10 but u would need a custom pistion neway right? why not just use the sbc rods and get pistons witht he right pin size
Old 04-30-2008, 11:47 PM
  #86
bl85c's Avatar
Car: '85 maro
If you're spending the money to have the 3500 crank machined I'd expect everything else to be replaced with forgings at one point. Not sure how much extra space would be needed, but why wouldn't you skip narrowing the rods altogether and machine the extra width into the crank since you'll be machining it anyway?
Old 05-02-2008, 09:36 PM
  #87
Car: 91 camaro
Engine: 3.1 v-6
thanks everyone you guys are awsome, and i am painting my car tomarow will post picks
Old 09-11-2008, 11:55 AM
  #88
seitz83's Avatar
i have a 3.1L mpfi out of my '91 firebird and it is completely disassembled and im looking to build it this winter. i ended up buying a double roller timing chain and gears and a performance camshaft and also a hypertech performance chip and performance fuel injectors. if i used these aftermarket parts and got aftermarket headers would it mess with the computer at all. will it be ok if i put all theres performance mods in.
Old 09-12-2008, 09:12 PM
  #89
Axle/Gears: ?
As long as your camshaft is reasonable and not overdone, your fine. Don't forget to bump up that ignition system, high-flow cats/muffler, and underdrive pulleys are optional.
Old 10-10-2008, 06:51 PM
  #90
Crazor1987's Avatar
I'm the new owner of a 1987 Camaro 2.8 V6 with less that 50,000K. I'm looking to add a little more horsepower and I was just wondering if someone could recommend a few things to start with that would give me a small horsepower boost and thats not going to cost me an arm and a leg.
Old 10-10-2008, 09:40 PM
  #91
Axle/Gears: ?
Headers would be my first choice, although the most expensive. Lesser cost items would be a Hypertech computer chip and Hypertech thermostat.
Old 10-11-2008, 10:02 AM
  #92
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Those chips are pretty much worthless. You can do alot more with the money. I'd do full exhaust and intake first. Then you can do a cam, rockers, etc.
Old 10-11-2008, 04:05 PM
  #93
grimmcs's Avatar
Car: 91 Camaro
--> 100%
Old 10-29-2008, 12:53 PM
  #94
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
Anyone know of a strut tower brace that will fit a V6 equipped third gen? Everywhere I search leads to STB for V8 cars only. Or has anyone made their own???? HMMM...
Old 10-29-2008, 12:55 PM
  #95
project89's Avatar
i was making them a long time ago.i think street lethal has my old stb he posted pics of it a while back and i may even have pictures of ti somewere ill look around
Old 10-29-2008, 01:07 PM
  #96
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 4L60
VERY COOL!!! Thankyou. I am very interested in seeing your pics of the stb. BTW how much were you charging for your stb?
Old 10-29-2008, 01:56 PM
  #97
project89's Avatar
i dont remeber i think it was like 150 bucks for a dbl adjustable stb
i wa smaking them out of chromoly tubing with adjustable hiem joints on each end
Old 11-03-2008, 10:54 AM
  #98
epic612's Avatar
Car: 1989 Firebird
are those intakes only for use with a carburetor? is there anything for the 2.8/3.1 MPFI?
Old 11-03-2008, 10:57 AM
  #99
project89's Avatar
u wont find anything other then the trulelo intake, or homebuild manifolds for the 2.8/3.1
though after looking at a 3.4 upper intake manifold the 3.4 mainfold looks to be somewhat of an upgrade over the stock 2.8/3.1, noone has tested to see if its worth any gains though
if u wanted to try u should be able to pick one up at ur local jy for a few bucks
Old 11-17-2008, 01:24 AM
  #100
epic612's Avatar
Car: 1989 Firebird
will the ones that say they're for the 2.8 work with the 3.1?
Quick Reply: after market parts for 60* motors
