Car stalls in summer heat
I've thrown this out here before but no one has had this happen to them, or at least back then so I'm going to throw this out here again.
My problem is this: when it gets Hot out, as in 90-100 degree summer days, the engine will sometimes sputter like it has no power and won't get very high rpms if I floor it. Then it will eventually shut off. Its like it can't breathe or its not getting enough gas feeling.
This will also happen if I'm driving down the highway and all of sudden I can't accelerate and start dropping in speed until the car slowly comes to a stop.
In both cases, I stop the engine and I can wait 5-10 minutes, start up the engine and it will be fine. When I shut it down or it shuts itself down and if I try to start it up in under a minute it will never start or it will have hardly enough power to move the car. Sometimes it will sputter for a little while and come out of it. The engine temp doesn't have to be that hot for this to happen.
I run 89 or 90 octane gas always. It doesn't matter if I take the air filter off. I have replaced the fuel filter probably twice now and just replaced it last summer. Fuel pressure is good but I've never been able to check it when this weird stuff happens. This seems to only happen every other summer but last summer it happened probably 5 times. If I pull over and take off the gas cap it will hiss out air for like 30 seconds(or a really long time). 1992 3.1 V6.
You guys have any suggestions before I start throwing parts out it to avoid headaches this summer? I'm leaning towards injectors getting too hot and I doubt they have been replaced ever.
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Re: Car stalls in summer heat
I had a similar issue with the ignition module. Perhaps clean the thermal grease off of it and reapply liberally?
Think I figured out what caused this in my v6. Whenever I take off the gas cap now in higher temperatures there is a huge whoosh sound that lasts a while. There is a gas tank vent valve that connects to the fuel pump sending unit, that thing that hangs by the tank and above the rear. I think it failed causing pressures to build up so high that the high-mileage fuel pump couldn't function. The fuel pump failed last winter and I need to replace this vent valve thing. I had a similar episode happen to my LT1 car that had no vent causing a bad walbro fuel pump in under 200 miles.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Dead post, there, dude.
Either way, that pressure relief only goes one way (out, not in). The tank vapor pressure relief valve the OP is referring to maintains the tank pressure, letting air in under vacuum, and releasing fuel vapor under pressure. If the tank stays under vacuum, the fuel may not be able to be taken up by the sending unit so the engine starves for gas.
1 Post
Car: 1989 Camaro RS--
Engine: MPFI
I was going to say vapor lock, I learned that a long time ago!
Was with a friend in his vet, driving up a winding road to a high mountain and his started doing the same thing. I said pull over and unscrew the gas cap, but don't take it off > gas sometimes spews out if you do. He did and the pressure was crazy.
Once he did that it was fine. I would just like to know whats the fix for the built up gas pressure?
Engine: 2.7L V6
Axle/Gears: 4.41
It's not fuel pressure, it's the vacuum that develops in the tank that causes the issues. Only way I can think to fix it is to replace the pressure relief valve located on a bracket behind the driver's rear wheel, and I'm not sure they can be bought at the dealer or not. May need to make some sort of bracket and shield and put a breather filter on there or something.
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
87 Trans Am, 5.7l and auto tranny: Ive been fighting this same problem. I've replaced the Fuel pump, Filter, rubber lines and the fuel tank vent valve and STILL have this problem. In the heat of the late afternoon and evening, it will stutter, sputter, stall and die. You can floor it and sometimes it will take off only to do it again but sometimes it just dies. Help?
Engine: L99 L98
Car: 89' Firebird
Engine: 3.4L V-6
Transmission: 700-R4
Axle/Gears: Whatever came stock!
I had a similar issue.....the grease from napa got all hard and crusty and prevented good gounding. I replaced and all was good.
Having that trouble with my wife's 92 RS - ignition is fine, ok when moving at a good pace but hit stop and go in the Tucson heat and she's dying out and need to cool it down with the hood up. Figuring it's the injectors freezing issue so I ordered a set from Southbay.
