another problem
Car: 91 firebird
Engine: V6
Axle/Gears: stock
another problem
iight i thought i fixed it by changing plus wires and cap and rotor but that didnt help now its hardly starting once every 10 or 15 tries and when i do get it started it idles half decent but u give it gas and it dies what can it be
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
Re: another problem
1. Weak Fuel Pressure - Check Pressure, Check Fuel Flow, Could Possibly Be A Bad Fuel Pump
2. Check/Clean Upper Plenum, Throttle Body (Making Sure To Clean Above/Below The Throttle Body Plate), And IAC.
3. Check Idle/Timing Adjustment - Use A Timing Light To Check The Ignition Timing, Check Idle With A Tachometer (Handheld Preferable Over In Car, Or Scanner)
4. Check Your Vacuum Pressure - Use A Vacuum Gauge And Go By The Specifications On Your Car
5. Check For Leaks Of Any Kind Near Or Around The Fuel Rail
6. Could Be A Intake Gasket Gone Bad
7. Pull The Fuel Pressure Regulator Vacuum Line Check For Fuel, If Fuel Pours Out Relace The Regulator
8. Check Spark Plugs - Look For Gap Bridging (Carbon Between The Electrode And Metal Tab) Could Cause Dead Cylinders
Hopefully Something Here Will Help You
-Christopher
-Christopher
