So is it official that there are no lowering springs for v6?
Old 01-14-2010, 12:43 PM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Axle/Gears: i dunno lolz
Damn this really sucks....especially since my car sits a little higher on the front then a STOCK firebird, since my springs are retarded...
Well I searched and found this thread https://www.thirdgen.org/forums/v6/5...g-springs.html
not much in it though
Old 01-14-2010, 06:23 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: So is it official that there are no lowering springs for v6?
you can cut your springs. or, you can get springs from "circle track" racing suppliers. you have to know the specs that you want, though (spring diameter, height, rate). There is no "firebird springs" or anything like that if you go this route. It'll be a lot cheaper, too.
Old 01-14-2010, 06:24 PM
Stephen's Avatar
Car: 87 GTA
What are the stock V6 spring rates?
Old 01-15-2010, 12:43 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
suspension techniques makes v6 lowering springs
Old 01-27-2010, 06:45 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
https://www.thirdgen.org/forums/v6/5...echniques.html
Dropzone makes these. Do a search on dropzone, Ive posted a few different times about them. I guess you can't find them online anymore, have to call them. Google them and you should be able to find the number. Too bad their prices have gone up so much, i got mine for $105 or so, gotta love inflation, lol.
Old 01-27-2010, 09:26 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Cut your stockers, not with a torch however or you'll de-temper them.
Old 01-28-2010, 06:37 AM
drdave88's Avatar
Engine: 6.0L
Maybe I havent ridden in an F-body with cut springs, but ive been in a few different cars with cut springs and the ride is absolute crap. People riding in those cars are a chiropractors dream. And most of these were only like 1/2 to 3/4 coil cut off. the ride gets unbelievably hard. lowering springs are a progressive rate spring so you dont have the rigidity like you do from cutting a spring. Just my input on that subject.
Old 01-28-2010, 09:10 AM
Stephen's Avatar
Car: 87 GTA
You haven't ridden in a car with cut springs, that were cut CORRECTLY then.
If you cut springs without adding excessive amounts of heat into a spring, the increased spring is very minimal & not noticeable.
I've cut them on my daily drivers, my wife's daily driver & pure autocross cars. Nobody ever complained because I do them CORRECTLY. Anyone can, with a little extra effort.
Old 01-31-2010, 11:18 PM
auto-x1990RS's Avatar
Car: 1990 Camaro RS
Engine: 3.1 MPFI V6
Axle/Gears: 3.23 open diff
or if you want to keep a smooth ride up front and not royally screwing over your suspension geometry (hurting handling ability), get drop spindles.
http://www.racecraft.com/index.php?m...products_id=70
Old 02-01-2010, 10:26 PM
RSFreak's Avatar
My f-bodies aren't my daily drivers so ride quality takes a back seat to handling and performance.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
Lanz06
09-14-2015 07:16 PM
crzycamaro86
09-12-2015 05:51 PM
lakeffect2
09-07-2015 03:52 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
Quick Reply: So is it official that there are no lowering springs for v6?
