My 3.5 swap project... - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 03-07-2010, 11:06 AM   #1
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
I figured i'd start a thread since i've been talking about it for a while...
Here is the car:
It was a 2.8/700R-4 car from the factory, it was bastardized with a V8 swap about 10 years ago. It seemed to be a pretty bad hack job, the car has a ton of wiring issues.
Last night the 327/700R-4 came out..
Now i get to sort out the wiring to find what's left of the old 2.8 harness, repair the rust, get rid of the A/C box and other crap, then fill all the holes and POR-15 the engine bay, tunnel and underside of the car.
I will be using the engine harness from my 91 Cavalier, '7730 ECM and of course the 3500 V6 that was in it, bolted to a 700R4.
My Spohn K member should be here in a few weeks, after that things should get rolling pretty fast. I'll keep updating this thread with pictures and any issues that pop up along the road.
Dave
DeathStarr89 is offline vBGarage Page   Reply With Quote
Old 03-07-2010, 12:13 PM   #2
Maverick H1L's Avatar
Car: 1988 IROC-Z28 with a V6
Engine: 3.1L V6 LH0/3100 L82 Hybrid
Transmission: Borg-Warner NWC T-5
Axle/Gears: 2HL/GU6 3.42 open
Re: My 3.5 swap project...
I've been wondering, was it you or someone else who was running a hybrid on a stock tune? If so, how? I haven't been on 60* too much lately.
If you need any harness parts, let me know. I have a box full of that stuff. But I'm keeping the C100.
Maverick H1L is offline vBGarage Page   Reply With Quote
Old 03-07-2010, 12:47 PM   #3
Engine: 450HP 355
Transmission: TH350
Nope, i had hundreds of hours into my tune in the Z24. Never had a hybrid, just full gen3 swaps.
Thanks, i'll keep that in mind.
Old 03-16-2010, 11:41 PM   #4
Engine: 450HP 355
Transmission: TH350
K member is here..
Old 03-17-2010, 08:59 PM   #5
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
where did the cross member come from...that looks like a hell of an upgrade over the stock one
Pillsbry10 is offline vBGarage Page   Reply With Quote
Old 03-18-2010, 12:38 AM   #6
Engine: 450HP 355
Transmission: TH350
that's from Spohn.
Old 03-18-2010, 10:31 AM   #7
Awesome-X's Avatar
Car: 87 Camaro, 86 Trans Am
Engine: 305, 305
Well this should be interesting. I'll certainly be keeping an eye on this!
Awesome-X is offline vBGarage Page   Reply With Quote
Old 03-28-2010, 01:19 AM   #8
Engine: 450HP 355
Transmission: TH350
Spohn K member installed (was a royal bitch, B- for fitment)...
1993 700R4 from a 4th gen, lower miles and clean.. bolted to a '04 3500 block for mockup of motor mounts and headers.
need to get a Sy/Ty pump installed this week.. then get the car back on 4 wheels so i can get the engine/trans installed.
More updates soon...
Old 03-28-2010, 11:38 PM   #9
Engine: 450HP 355
Transmission: TH350
ran into a few snags so i put the mockup engine in anyways...
I need to find a V6 Fbody locally and get some measurements, i know this engine is sitting too far forward right now. I have a feeling i'm going to have to flip the trans mount around to move it back another couple inches...
I also get to replace the tops of the front strut towers, mine are pretty rusted out..
Old 03-29-2010, 12:06 AM   #10
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
so you're swapping in a FWD 3500 V6? I'm gonna be watching this one.
chevyracingrox is offline vBGarage Page   Reply With Quote
Old 03-29-2010, 02:39 PM   #11
Car: 1992 Camaro RS
Engine: 3.1L POS
Transmission: no idea
Axle/Gears: donno cause i just fing got it!
alright so this is cool...ill be sure to run all my swaps by you if you could pick another motor to put in what would it be?
avengedsoul666 is offline vBGarage Page   Reply With Quote
Old 03-30-2010, 03:13 PM   #12
DemonKnightDK's Avatar
Car: 1985 Firebird
Engine: 3.1L (planning for a turbo)
so a FWD engine will work in these cars? i thought the starter or something was on the wrong side? have I missed a major discovery (i've been absent for quite a wile)
DemonKnightDK is offline vBGarage Page   Reply With Quote
Old 03-30-2010, 03:28 PM   #13
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Kinda like to see were this goes.
bluegrassz is offline vBGarage Page   Reply With Quote
Old 03-30-2010, 03:52 PM   #14
Car: 86 Firebird SE
Engine: 2.8L
consider me subscribed. If this works for a reasonable cost, this is a major breakthrough.
86ttopbird is offline vBGarage Page   Reply With Quote
Old 03-30-2010, 05:39 PM   #15
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
I believe he's using that for mock up purposes...there won't be a starter bolted to it so, it doesn't matter,...
AM91Camaro_RS is offline vBGarage Page   Reply With Quote
Old 03-30-2010, 08:42 PM   #16
Engine: 450HP 355
Transmission: TH350
the 700R4 doesn't care what side the starter is on, the T5 does. Just for kicks i'll bolt my starter on and take pics.
It's the flexplate cover that i'm going to have to modify, i don't have one so i'll probably just make one for it.
Reasonable cost may be hard to calculate, i found that it would be possible to modify the stock K member and make this work. I found this out after i had purchased the Spohn unit so I'll take the $600 hit on that one.
So far i've dropped about $1500 into the car, most of that is just getting it safe to drive. All new brakes, suspension, new strut towers are coming, new fuel and brake lines and about $60 worth of POR15.
1st design IROC wheels with all new tires are up next on my list. It'll probably be next year before i swap in a limited slip diff though.
Old 03-30-2010, 09:06 PM   #17
Car: 91 Camaro
oh, you are using the FWD block? oops.
Old 03-30-2010, 11:06 PM   #18
Engine: 450HP 355
Transmission: TH350
Here is my starter bolted on the drivers side.
I've got the stock SBC mounts bolted to the K member, it looks like building mounts for this is going to be fairly easy. I need to take a few measurements and make sure the driveline angle is correct before going too far though.
More pics soon...
Old 03-30-2010, 11:12 PM   #19
i thought the major problem with this swap was that there was no way to mount the engine (being that it's FWD it doesn't have RWD mounts), however, I never looked to closely at the places GM mounts the FWD engines. I know a DSM has engine mounts on the 4G63 so it could be turned 90* for a RWD platform. very interesting indeed.
Old 03-30-2010, 11:26 PM   #20
Engine: 450HP 355
Transmission: TH350
the bosses are there but they are configured differently than the RWD blocks. I'm basically going to drill some different holes in the SBC clamshells, weld in some spacers and use longer high grade bolts.
You can see how close everything is in this pic..
Old 03-30-2010, 11:36 PM   #21
so why have we all been wasting our time with a GEN I V6 then? I would think someone would've gotten the crazy idea before now. seriously, the difference in power and weight is damn good. i would expect a stock 3.5 to haul some pretty good ***. maybe not V8 good, but damn close. purple82TA have you ever done a search on this kind of thing? it's full of "almost impossble" and "not worth the effort" comments.
Old 03-31-2010, 01:55 PM   #22
Engine: 450HP 355
Transmission: TH350
I saw some of the topics several years ago which was one reason I never thought to keep my T/A for this swap. it's a shame too because it was in much better shape.
I ran a 13.07 @ 107.44 with the Z24 and this same engine, it should be good for around the same times in the Camaro. 12's would be nice but for now I'll settle for running/driving.
Old 04-01-2010, 02:02 AM   #23
Car: 1985 Firebird
okay so with a 700r4 trans all that is in the way is the motor mounts ? THATS IT! If you get those mounts lined up correctly would you be willing to make some more or somthing if enough people wanted them? cause I would buy a set in a heart beat if they werent like 300$ or somthing (I cant come up with that kinda money) but I would love to just drop a 3500 or 3900 from a wrecked most any thing GM 2007+ mid sizer.. and have awsome power/MPG...(not that i have THAT kind of money either, but some I would have it and I would like to have the mounts on had lol..)
Old 04-01-2010, 07:37 AM   #24
Engine: 450HP 355
Transmission: TH350
Maybe.. but most likely i'll just CAD them up so you can have a local place make them.
I decided last night not to use the metal shell from the SBC block, i'm just going to make a pair that bolt directly to the V6 block and line up with the pads on the K member. This way i won't have to worry about long bolts flexing around.
Old 04-01-2010, 04:27 PM   #25
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Glad to see someone try this!!
You said you are going to use the 7730 ecm, which is was the 91/92 fbody came with IIRC.
I'm still trying to figure out how the 7730 will run a 98+ tranny. But I havent looked into it.
Dale is offline vBGarage Page   Reply With Quote
Old 04-01-2010, 07:14 PM   #26
Engine: 450HP 355
Transmission: TH350
I was going to use the 98+ trans but decided against it. the 700R4 will do for now. I wanted to keep things simple considering all the other work that i'm having to do to the car.
To run that trans i had planned to use a trans computer from a 93 Chevy diesel truck with the 4L80e. It's been used to run several E trannies including the 4L60e.
Old 04-02-2010, 12:07 AM   #27
Engine: 450HP 355
Transmission: TH350
Post deleted to save bandwidth...
Old 04-02-2010, 08:23 PM   #28
Car: 1985 Firebird
cad specs would be awesome. I could probably get the local votech school to make em for me ^_^
Old 04-03-2010, 10:29 PM   #29
Car: 86 Firebird SE
Engine: 2.8L
Wow man looks like you really do have this thing well planned out. I remember I sent you a message asking you about it. If a 3500 will go into my Firebird then i will defenitely go for it. What mods do you have to make to the stock K-member?
Old 04-03-2010, 11:45 PM   #30
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I had always heard that the RWD trans wouldn't bolt to the FWD block! It'll be really interesting to see how she runs. I would love to try this swap myself. The wrecking yards around here are full of 3x00 engines!
RSFreak is offline vBGarage Page   Reply With Quote
Old 04-04-2010, 12:24 AM   #31
Engine: 450HP 355
Transmission: TH350
Quote:
I used the Spohn K member but i bet if you cut the stock one where i put the yellow lines in this pic, then boxed it back in the 3x00 pan should clear.
I'm waiting on a few things from thirdgen ranch, once they arrive i'll be able to start moving ahead again.
Just a note, there is a difference between the RWD and FWD flex plates. the RWD ones are slightly larger. The pattern for the converter is the same though. Since i'm using a FWD starter i'm going to use the plate from a '05 3500 V6 so i don't have to do any shimming. I just hope it can handle the torque.. lol
as for cad specs on the mounts, these are being made to bolt to the SBC pads which is why they are offset. If a person was to modify the stock k member then mounts would be even easier when using the V6 location and brackets. I haven't seen the V6 mounts but i'd be willing to bet you could mod them really easy.
Old 04-04-2010, 12:29 AM   #32
Car: 86 Firebird SE
Engine: 2.8L
Sweet!! good to know! One other thing i am wondering is would the 3500 oil pan have decent ground clearance? They seem like they are real deep and would sit low to the ground.
Old 04-04-2010, 12:48 AM   #33
Engine: 450HP 355
Transmission: TH350
It sits about level with the lower tube on the Spohn unit, i won't know about ground clearance till the car is off the jack stands.
Old 04-04-2010, 04:17 PM   #34
Awesome-X's Avatar
Engine: 305, 305
Well it looks like your swap is chugging right along. What cars are the 3500's in?
Old 04-04-2010, 05:15 PM   #35
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
sweetness, very interesting.
Tobias05 is offline vBGarage Page   Reply With Quote
Old 04-04-2010, 11:25 PM   #36
Engine: 450HP 355
Transmission: TH350
2004-2006 Malibu and Malibu Maxx, and a few others like the early G6's.
I got all the steel cut for the mounts and they are tacked together right now, need to do some test fitting and measuring before i finish weld them and drill all the holes. I'll post up pics when they are complete...
Old 04-04-2010, 11:45 PM   #37
Car: 86 Firebird SE
Engine: 2.8L
Come on! The suspense is killing me!! Did you get any farther?
Old 04-04-2010, 11:46 PM   #38
firstfirebird's Avatar
It's a V6, who in their right mind pulls a v8 to put in a v6? HAHA
**me remembers tearing apart a GTA to put parts on my car**
firstfirebird is offline vBGarage Page   Reply With Quote
Old 04-04-2010, 11:48 PM   #39
Car: 86 Firebird SE
Engine: 2.8L
If this works, i know what i will be swapping in. I was pretty set on an LT1 until i read this. I was even looking into a hybrid. But this is a major breakthrough.
Old 04-05-2010, 12:30 AM   #40
It's going to work.
There are more guys doing this, and has been done yrs ago in 4th gens
Old 04-05-2010, 03:03 AM   #41
Car: 1985 Firebird
the 3500 was to replace the 3800, it was used in quite a few cars..
it was in almost all V6 malibus out side SS and the newer ones getting the 3.6 it replaced the 3800 in the impala at some point IIRC, the G6 as stated, I think the Lucerne once the 3800 stopped being made, its quite the common engine really... if it just takes a new motor mount and starter/flexplate to use a 700-r4 then this will almost definalty surpas the hybrid system as a quick swap...
Old 04-05-2010, 07:30 AM   #42
Engine: 450HP 355
Transmission: TH350
there is still the issue of needing an external 7x crank trigger to run DIS on it. I've got the trigger already since this engine was in my Z24 though..
There is another Jbody guy doing a similar swap in a 88 Camaro, He's going to post up over here when he pulls his 2.8 and starts modding the stock K member to fit in a gen3 3400.
Old 04-05-2010, 07:08 PM   #43
Car: 1984 Camaro berlinetta
Engine: LG4 305
Transmission: 700-R4
Axle/Gears: 3.08 open diff
i still have all the parts for my G-body 3400 swap that never happend. may do this to the berlinetta 2.8L i am thinking of buying. has alot better body then the z28 it actualy has floors. sad part is it would then be faster then the z
01GPGT is offline vBGarage Page   Reply With Quote
Old 04-08-2010, 04:45 PM   #44
Car: 1985 Firebird
put z34 badges on it lol
Z/34Berlinetta
Old 04-09-2010, 05:55 AM   #45
Looking good Purple....
If this works, i know what i will be swapping in. I was pretty set on an LT1 until i read this. I was even looking into a hybrid. But this is a major breakthrough....
Why would you consider it a major breakthrough lol....?
Street Lethal is offline vBGarage Page   Reply With Quote
Old 04-09-2010, 09:05 AM   #46
WS6LOVE's Avatar
Car: '86 T/A
Engine: Vortec 406sbc-carbed
Transmission: 700r4-vette servo/B&M shift kit.
Axle/Gears: Ready to splode
This is pretty cool I wanted to do the same thing to my old SCCA car but didn't want to spend the $ at the time. And don't let the guys get ya down on using the v6 instead of a v8. Built right, those 6's are sweet. The cars seem to handle better too. I taught several of my friends how to drift in mine
WS6LOVE is offline vBGarage Page   Reply With Quote
Old 04-09-2010, 09:20 AM   #47
Deleted Post, Item Was Just Sold....
Old 04-09-2010, 09:08 PM   #48
Engine: 450HP 355
Transmission: TH350
Thanks, that's actually something i need to start looking into. the 93 trans just has a standard VSS, no cable output. My speedo of course is cable, and i think it goes up to like 110 or 115..
was there an electronic version that i could swap in there?
I can use the ECM to compensate for whatever the VSS PPM is and output the correct signal to the speedo. That's how the Jbodies are.
On a side note, i feel dumb for asking but how the hell do you get the cluster out of these Camaros?
I remember it being fairly easy to get the one out of my '82 T/A
BTW, my IROC wheels showed up today but the rest of my stuff from thirdgen ranch didn't.
Old 04-09-2010, 09:10 PM   #49
Dave (Purple) let me know if you need an A/C Delete Box for your project....
Old 04-09-2010, 10:41 PM   #50
1. Are you using the 700R4 you mentioned or a 4L60/E? If it's the 700R4, you can just swap the speedo cable parts in place of the electronic VSS if you so desire, and you can use the existing wiring from the adaptor unit on the back of the speedo head to the current ECM (if the car has one) or retrofit that way. That's one option.
2. The electronic cluster was introduced in the Camaro in 89-90, and has it through 92. You'd have to ask someone else as to how to get to the cluster to remove it and swap. There are 2 tech articles on the TGO main page that you should look at, "Swapping an IROC cluster for a base model cluster" and "Swapping an Electronic Speedometer into your base model Firebird", the first giving basic Camaro directions, and the second on basic system wiring. That's the second option. However, to do this, you will probably need to rip out the whole dash to run some wiring, as neither engine system (V6 or V8) in the 86 Camaro had the electronic stuff.
I hope that will at least get you started in the right direction.
Thread Thread Starter Forum Replies Last Post
86 T-top IROC-Z LSX Iron 408 LS3 Built t56 sell or trade as roller spohn bmr umi ambainb Camaros for Sale 11 04-25-2016 10:21 PM
More HP on a budget gta90 TPI 40 09-15-2015 05:00 PM
Audio idea Steven 86IROC-Z Car Audio 16 09-07-2015 09:05 AM
87 Firebird SB 350 in car cam swap theshackle Tech / General Engine 2 08-22-2015 07:52 PM
Advice for dealing with trans during engine swap. Hello, Michael Engine Swap 8 08-20-2015 04:19 PM
Go Back   Third Generation F-Body Message Boards >
Tags
2004, 28, 35, 700r, 7x, conversion, engine, fiero, lx9, malibu, ps, pump, swap, trigger, v6, v8, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
