5 Speed Redline? - Third Generation F-Body Message Boards
5 Speed Redline?
Thread Tools Search this Thread
Old 06-21-2010, 11:28 PM   #1
Car: 1987 Camaro Sport Coupe
Engine: 2.8 MPFI
Transmission: 5-Speed Standard
5 Speed Redline?
So I have a 1987 Camaro with a 2.8l and 5-speed transmission. My car has the stupid massive gas gauge and three idiot lights. So my question would be…*How far can I take each gear, in mph or km. Thanks for everthing
nezzie09 is offline vBGarage Page   Reply With Quote
Old 06-22-2010, 12:33 AM   #2
Car: 1984 Firebird
Engine: 2.8L V6
Re: 5 Speed Redline?
You could get a tach. :P
As for what speeds.. *shrug* someone else will have to answer or you could check your manual if you have one.
[Edit]Nevermind, the manual has speeds for "best compromise between performance and fuel economy", not all out rod throwing crazy[/edit]
In the event that you do get a tach; in another thread Gumby seems to say that it was 6500RPM (said that his rear mounted tach matched the stock v6 one)
http://www.thirdgen.org/techboard/po...60-post27.html
Oelmuvun is offline vBGarage Page   Reply With Quote
Old 06-22-2010, 02:19 AM   #3
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ever ridden a dirt bike or other off road thingy?
You should know when to shift then, you'll feel the power peak then start to drop off.
You'll run out of poop before ya over rev.
Gumby is offline vBGarage Page   Reply With Quote
Old 06-22-2010, 03:05 PM   #4
Engine: 2.8 MPFI
I know that. However, for a 23 year old engine, I was looking for some info.
Thread Thread Starter Forum Replies Last Post
[CA] 1989 Trans Am w/ just 32k miles for sale jrdturbo Firebirds for Sale 26 03-31-2016 03:58 PM
1991 Camaro Speedometer Board; Broken, now working! Elephantismo Electronics 12 11-14-2015 10:40 PM
Is it the Ignition Control Module...AGAIN?!? RedLeader289 Electronics 6 09-23-2015 07:50 AM
700r4 locked into 1st HikoriYami Transmissions and Drivetrain 2 09-21-2015 08:11 PM
WTB 87-91 iroc/z28 5 speed FLAP Camaros Wanted 0 09-02-2015 10:22 AM
Go Back   Third Generation F-Body Message Boards >
Tags
1987, 28, 28l, 28mpfi, camaro, line, liter, mpfi, red, redline, speed, tachometer, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright © 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
