'91 3.1 Camaro: Where's the Oil Pressure Sending Unit?
'91 3.1 : My oil pressure guage is wacked and I'm guessing the oil pressure sending unit is bad/dirty/broke. Where is it located? Beside the oil filter?
How hard is it to change? What should I expect to pay for a new one?
Engine: LH0 3.1L
yup, its right by the oil filter. very easy to replace.when my gauge didn't work i didn't know if it was the sensor or the connector(mine was cracked) so i replaced both. the sensor was $25. just disconnect it, unscrew, replace.
you'll need a rather large wrench though, maybe a 22mm....or a big crecent wrench.
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Dan
1990 3.1L RS
You have a gauge.
It's the large cylinder connected to the oil filter housing. You MAY be able to remove it with a 10mm wrench. One wire to it!
The light sensor is a 26mm socket. I discovered that as I need to swap my light sensor for the guage sensor. I'm using the old one from my S-10 Blazer, it's identical to new one
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Chat Soon,
KED85
Karl
Dan gave the price & he's correct. That's why I'm taking my old oil gauge pressure sensor off my 1985 S-10 Blazer. It still works, after 211,500 miles. Why waste $25?
Chat Soon,
KED85
Karl
Chat Soon,
KED85
Karl
Engine: LH0 3.1L
$25 is the kragen price. if you go to the dealer expect to pay WAY more.
Dan
1990 3.1L RS
Dan
1990 3.1L RS
Ghettobird52
12-29-2023 08:23 AM
ambainb
04-25-2016 09:21 PM
