Get broken bolts out?
Old 09-03-2011, 11:51 AM
ktmracerx009's Avatar
Car: 1987 Camaro
Engine: 2.8 tpi
Transmission: 5 speed
Hey guys got the manifold off on the passenger side and the two rear bolts were broken off which was causing the, the bottom one had a stub on it and I could get it out but the top one ist broken off and can't grab it, same story for the middle one that I broke
What is the best way to get them out?
Right now I'm out drilling into the middle one using my drenel tool with a 90 degree head
Any tips would be helpful this is taking firever
Old 09-03-2011, 12:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Get broken bolts out?
drill and an E-Z out, but are they in aluminum? if they are, they may never come out since the steel bolts tend to fuse with hte aluminum over time.
Old 09-03-2011, 02:53 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
You can weld a nut onto what's left of the bolt to get it out
Old 09-03-2011, 03:13 PM
Car: 1987 Camaro
Engine: 2.8 tpi
Yeah I have an easy out but I can't drill enough into the bolt to get it to catch
Old 09-03-2011, 06:05 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Dremels suck for drilling, use a real drill on it. Couple different ways to do it, bolt extractor is one way, welding a nut or a bolt onto it is another, sometimes you can slot one for a screwdriver, but that would not at all work for an exhaust manifold bolt, worst case scenario, drill it out completely and retap the head with a heli coil or similar. Also the extractors have to be tapped in with a hammer(carefully). So that might be why it won't bite if you are just trying to push it in.
Old 09-04-2011, 01:09 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
It also might be easier in the long run just to pull the head so you can work it on a bench.
Old 09-04-2011, 07:20 AM
SWenholdIV's Avatar
Car: 1987 Iroc-Z
Engine: no clue-_-
DO NOT USE AN E-Z OUT!!
Personal experience here: with rust occuring over time and with all of the heating/cooling cycles that engine's gone through over it's life there can be more fused metal in the exhaust bolts of a head then probably anything else on the car. Then what happens when you take an (not so) ez-out to it? The hardened carbon steel gets brittle and breaks. THEN you're left with drilling out some of the hardest material made by man. Not an easy job, even with diamond studded dremel burs.
IF you can it's much better to take the whole head off, drill it out AS STRAIGHT AS POSSIBLE, and tap it. If you can't do that then the next best thing IMO is, again as straight as possible, drill it out with whatever you can find. Yes a drill with either kobalt or some other hardened coating will last longer then a dremel. Then though because your not gonna be able to get it straight, go find a heli-coil set that matches the exhaust thread sizes, and go through the steps with that. A lot of times, I'm actually looking for an excuse to use mine.
Old 09-04-2011, 07:21 AM
J91
J91's Avatar
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Pull the head and do it right, drill it and remove, retap or as a last resort install a helicoil. Once done reinstall bolt using anti-sieze.....
Old 09-04-2011, 02:58 PM
Car: 1987 Camaro
Engine: 2.8 tpi
Yeah i was debating taking the head off so I guess I will since the drenel isn't going anywhere
I do have the heli coil in the tool box
Thanks for all the help guys
Old 09-04-2011, 07:04 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Put the manifold back on and use that to align the drill bit.
Thread size for the manifold bolts is M8x1.75... I'd go out and get all new bolts to start with and install them with anti-seize.
MY87LT
Aftermarket Product Review
06-07-2016 09:47 PM
skeltor
02-02-2016 10:37 AM
snakeshooter
09-07-2015 11:15 AM
Jlanz55
09-06-2015 07:28 PM
UltRoadWarrior9
09-02-2015 08:24 PM
Quick Reply: Get broken bolts out?
