tpi
Old 09-16-2011, 08:10 AM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
tpi
hi how big is the opening on the trottle body vs a tpi one or lt1
Old 09-17-2011, 10:26 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: tpi
Throttle body itself, 52mm, idk what size TPIs have, but our plenums have mouths that are smaller than the bores on our throttle bodies.
Old 09-17-2011, 03:28 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: tpi
TPI & LT1 are both dual 48 mm.
LS1 is single 75 mm.
Neither is an easy upgrade, to the point that I can't recall ever seeing a v8 TB on our engines....
Old 09-17-2011, 04:01 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: tpi
There was a pic posted quite some time ago where someone grafted the front part of a TPI plenum into the upper plenum on a 2.8 to put on the TPI throttle body... Might be difficult to find. And that's about the only way to get the TPI TB onto the V6 plenum without some major work to make an adapter plate.
Old 09-17-2011, 04:23 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: tpi
I've seen that done 3 different ways, this pic was the better looking of the 2 ways using the stock 2.8/3.1 Fbody parts.
The other was Curtis "TurboZ24" who had a LT1 TB flange welded to a 3.4 UIM
Now, this guy did something pretty cool looking for his Fiero...
http://60degreev6.com/forum/showthre...4-V6-I-love-it!
Old 09-17-2011, 10:12 PM
Engine: 3.8, 3.4
Re: tpi
He didn't make it, they sell that at one of the fiero stores, should bolt up to our engines just fine, though throttle cables would be an obvious issue.
Old 09-17-2011, 10:53 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: tpi
If you're talking about the one in the link, the intake will be backwards.
It sounds like he prototyped it, then who ever made the original for him is now selling them.
Old 09-18-2011, 09:13 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: tpi
I don't see how the Fiero intake would be backwards... The lower plenum is reversible, and the fuel rail bolts are on the left side (if the DTB intake was pointed towards the front of the car as on our cars stock) just like our stock lower plenum, as seen in the pic of the red manifold on page 2 of the link. The only thing I see being a problem would be the throttle cable, as mentioned above. Looks like a swap to a J-body cable would be needed as in the 3x00 and hybrid swaps. :edit, again: Only question I have is, where does the brake booster connect?
Those TBs look like the ones I've seen on Mitsu/Chrysler 3.0 V6 engines...
Old 09-18-2011, 09:47 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
Re: tpi
i wanted to know that the stock bore was on the v6 one and is it worth the time to put a lt/tpi 48mm throttle body on the v6 intake.
Old 09-18-2011, 11:53 PM
Re: tpi
No.
stalkier
12-06-2015 11:25 PM
ChaseDale3and8
09-01-2015 01:49 PM
Keith5
08-27-2015 04:37 PM
theurge
08-21-2015 12:46 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: tpi
