Convert V-belt to serpentine
Old 02-17-2012, 08:50 PM
cozwurth's Avatar
I want to swap a serpentine belt setup from an '87 or '89 S-10 to my '85 2.8 Camaro. I have searched some, and found out that I have to change the front cover and water pump when I go to the reverse rotation water pump. No problem there. What do I have to do with the wiring for the alternator? Can I just switch the plug, or is there more to it?
Dave
Old 02-17-2012, 08:57 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Convert V-belt to serpentine
Some wiring info below:
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Old 02-17-2012, 09:53 PM
cozwurth's Avatar
James,
Thanks for the links. I think the first one has the info I needed. I saw that link, I think, but thought it was only for V-8 setups. I guess I should have looked a little closer. I'll find out tomorrow exactly what I have left of the '87 S-10 setup. I know that the '89 is complete.
Dave
Old 02-18-2012, 08:01 AM
ex-x-fire's Avatar
You might need to change the oil pan too, the part that seals to the timing cover changed around 87-89. The newer ones are more like the sbc in that respect.
Old 02-18-2012, 08:41 AM
cozwurth's Avatar
Thanks, ex. I'll take a close look at it today.
Old 02-18-2012, 04:35 PM
cozwurth's Avatar
ex, you were right about the oil pan. There is a difference in the front of the pan and the bottom of the front cover. Is the rear of the pan the same? I'll be pulling the pan and front cover off of the '87 engine since it's trashed, and I'll be using the brackets and accessories from the '89.
84LsxZ28
05-17-2020 02:21 PM
FormulasOnly
07-23-2018 08:47 AM
jrdturbo
03-31-2016 02:58 PM
okfoz
10-13-2015 02:19 PM
bjpotter
10-02-2015 09:12 AM
Quick Reply: Convert V-belt to serpentine
