I cant stop this leak
Re: I cant stop this leak
if u mean its spraying out from under the the nut were the line is yes there is an oring under there u can replace.
if its not the oring its possible that the threads got crossthreaded at which point u will have to goto the junkyard and grab a new fuel rail and cold start injector
The threads seem fine, i wasnt aware there was an oring inside. And yeah i meant where the line goes through the hole in the top of the nut. I will look for an oring that will fit. If anyone has anymore info, let me know.
bubbaz28
09-18-2015 02:09 PM
