86 Camaro and parts for 400 bucks should I buy it?
Old 12-31-2012, 01:20 PM
VandykeT/A's Avatar
A friend of mine is wanting to sell his 86 camaro base car. Its got the manual windows and its the berlinetta style body. 2.8 automatic the interior is in good condition, dash isn't cracked or anything, the car runs out great and from what they tell me I can drive it home. The car is one color (silver) but its faded so it'll need to be painted. Its got a old set of cragers on it and I'm not sure about the tires. It comes with a 350 engine thats suppose to be good, 4 bolt main, 3970010 casting, and crappy 882 heads. A Th350 transmission (suppose to be good) and a Z28 rear bumper cover for 400 bucks. I've got alot of projects all ready but to me it seems like a steal for something I can drive home that looks pretty decent. Should I buy it or not?
Old 12-31-2012, 01:55 PM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Re: 86 Camaro and parts for 400 bucks should I buy it?
Switching a v-6 to a v-8 car is a lot of work and money. You're going to need new cluster instruments,ecm, run a new wiring harness, front end accessories find a 700r4 instead of the predecessor th-350 and a new exhaust system. I'd pass unless you would rather keep it a v6 and switch to a 3.4 v6 with a neat little cam and putt putt around in it.
Old 12-31-2012, 02:30 PM
project89's Avatar
u do not need a new cluster , u do hpowever need to switch the tach if u want it to work right
the front end only needs v8 springs and engine mounts , if the th350 is a 9inch tailshaft version it goes in with a simple tq arm kit form b&m
Old 12-31-2012, 03:29 PM
neilb's Avatar
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
$400.00 for a complete running car, and a new engine/trans combo? Grab it up! As long as the body is solid it would be a great project car! Where are these deals when I need them?
Old 12-31-2012, 08:24 PM
VandykeT/A's Avatar
I don't have any intentions on swapping it over to a V8. I planned on buying it and using a few misc parts, maybe ride it a little while and sell it. I figured I could get a couple hundred bucks out of the engine and get the car running and clean it up and sell it for 700-800 bucks. I just seemed like a good deal and he was gonna have it crushed if I didn't buy it.
Old 12-31-2012, 10:01 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I'd buy it. Hell, you could swap what you need off it for what you have, make it look decent and run alright, and sell it for a grand.
Old 01-01-2013, 09:39 AM
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
I'd buy it, if I were in the OP's shoes.
Old 01-01-2013, 01:33 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I agree with the above
Old 01-01-2013, 10:29 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
If you don't take it, you're nuts. You get 2 engines with a WHOLE CAR for half of what I paid for my 88 roller with an interior full of half junk parts!
Old 01-02-2013, 07:53 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Take it!!!!!!! Use it as a put around car and then sell it if you don't like it for more than you paid, plus sell the extra engine and trans. Seems to me you could make an easy $600 or more and still get some use out of the car.
Old 01-02-2013, 07:57 AM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
^ what he said. nothing wrong with cruising a v6 3rdgen at that price.
Old 01-03-2013, 11:30 AM
VandykeT/A's Avatar
Well I bought it. When I went to get it, it was running just a smooth as could be, we revved it up and it done fine. Turned on the headlights and the engine died. Well first thought was bad alternator, no big deal. We boosted it off and couldn't get it to start for some reason so I went home got a dolly and towed it home. Next day it fired right up but it sounded like someone was in the oil pan with a claw hammer trying to get out. Rod knock wasn't the word for it. I've decided to make a drag car out of it and use the interior parts in my 86 Trans Am.
Old 01-03-2013, 03:11 PM
fasteddi's Avatar
Car: 1991 Camaro RS
So your selling the V6 stuff?? Making it a V8 race car?
Old 01-03-2013, 04:04 PM
VandykeT/A's Avatar
Yep, getting rid of the V6 stuff and going small block.
Old 01-03-2013, 05:28 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
gen1 carb small blocks isn't worth it, to many cheap LS-- FI V8s to be had.
gotta go right to carb BB if you don't want to feel like you still have a V6 as everyone will still be faster then you.
least with a 6 when you keep it, it feels good.
Old 01-03-2013, 07:42 PM
Car: 1989 Camaro RS
Engine: LH6
Meh, you can make the SBC fast, but it takes more than a LS. If you are doing a V8, the 5.3 LM7 is your best choice, 10 HP less than a LS1 and can be had for under $500.
Old 01-04-2013, 09:50 AM
2007xl50's Avatar
Engine: LB9/3.1
That sucks man,but as long as you have a plan for the car then no big deal I guess. I know you can make a SCB run real good in a 3rd gen so all should be good.
camaro71633
09-01-2015 10:24 AM
lakeffect2
08-23-2015 08:44 AM
Street Lethal
08-12-2015 11:33 AM
1nastygta
08-08-2015 07:38 PM
Quick Reply: 86 Camaro and parts for 400 bucks should I buy it?
