difference between 85 and 89 2.8
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Got a line on a good running low km 2.8 its in a 85 firebird. Now I have a 89 camaeo rs . What the differences in the motors.
Re: difference between 85 and 89 2.8
It has been mentioned here in several threads that the earlier 2.8 had a weak crank which was taken care of sometime in and around 1987 , ish .
The guys here have told me of other improvements to the later 2.8 such as better head porting also .
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Ya I have read about the crank and oiling system but was not sure when they were upgraded. Visually they look the same other then belt set up
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
1985 could be a small or large journal crank . 1986 and up are large journal .
The 85 will have v belts & the 89 will have a serp. belt system. If you want to retain whats on your original motor you'll have to swap over the water pump, timing cover & the oil pan.
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
Thanks for the reply everyone. Deal fell through. Guy had pulled motor and had pulled parts from it. Was not willing to pay good koney for a motor I had know way to run some tests on
Springster
09-13-2015 01:38 PM
