Oil Problem
Car: 1986 Pontiac Firebird
Engine: 2.8L V6 MFI
Oil Problem
So I've had a problem with my oil light coming on. Took it to the mechanic and they told me the oil pump wasn't pumping so they replaced the oil pump, oil pan gasket, fuel filter, and oil pressure switch. The mechanic stated that the pump and switch are working properly.
I took the my car back and the light is still coming on only when stopped and goes away when accelerating. The mechanic isn't sure why but stated to drive it long distances, especially on highways, and to bring it back in two weeks to see if the light goes away.
My question is is there possibly another problem or would the driving like recommended work?
** 1986 Firebird Base V6 2.8L Engine **
Engine: 2.8L V6 MFI
Car: 1988 Firebird
Engine: Built 3.4 swap
Transmission: worldclass T5
Axle/Gears: 3.23 28 spine posi with moser axles
Re: Oil Problem
Those 60° v6's are touchy when it comes to oil pressure when they get up there in miles.....being they have those horrible factory aluminum pumps that tend to ware out quick
Get a gauge....that engine may thank you one day
Engine: 2.8L V6 MFI
Re: Oil Problem
Well apparently the mechanic couldn't solve the problem and stated that a bearing is shot inside the engine and stated that I would need a engine rebuild.
Car: 1987 Camaro SC
Engine: 2.8
Re: Oil Problem
Now there is 2 oil pressure switches one when it receives pressure it will send fire to the fuel pump, this one has 2 wires, the other one has one wire and it sends info to the oil pressure light. Mine does the same thing, 2.8 87 sc. Im thinking its a bad pigtail, or a bad pressure switch.. my engine is a rebuild probably only have 5-6 thousand miles on it. Mine will come on when warmed up and at a stop. sometimes stall.
Car: 1987 Camaro SC
Engine: 2.8
Street Lethal
04-30-2019 12:14 PM
ambainb
04-25-2016 09:21 PM
Navy8125
08-21-2015 09:32 AM
92camaroJoe
08-13-2015 06:07 AM
