Relays
Relays
What are the two relays on the right side of the brake booster on the firewall? 2.8 firebird barn find with rat chewed wiring looks like this is going to take a while to repair. They even ate wires to turn signals and couple plug wires.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Relays
once you hit 7psi of oil pressure the bypass will kick the pump on. It can wait if needed, it will run without a working relay.
gta892000
09-16-2015 12:37 AM
