car wont start
Old 10-04-2015, 11:35 PM
Juan Santos's Avatar
car wont start
Any help car wont srart is giving me code 34 and 42 can a faulty maf sensor cause the car not to start? Already check spark and gas their ok but I cranck it and wount start I dont know what to do
Old 10-06-2015, 09:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: car wont start
use starting fluid, if it tries to start, you know it bad fuel, if it won't even pop, you have bad spark.........
Old 10-07-2015, 11:20 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: car wont start
What year? What engine? etc. etc.
Old 10-15-2015, 11:52 AM
Re: car wont start
Its a 1989 camaro rs v6 2.8L
Old 10-15-2015, 11:59 AM
Re: car wont start
Havent try it ill get a started fluid now after work. I dont thing its has bad fuel because I filled the tank 2 days before it stop working. I check fuel pressure and its ok also check the injectors and are also ok. For spark I check spark fron the ignition coil to the distributor and from the distributor to the cables finally from the cable to the spark and everything have spark. Also use a spark testes and it look ok.
Can a bad ignition module send some kind of a signal to the ecm or something like that? That is one of the last parts I replace before the car stop working
Old 10-16-2015, 12:06 AM
AmpleUnicorn88's Avatar
Engine: 305 TBI/305 TPI
Transmission: World Class T5/missing
Axle/Gears: 3.08/G92 3.45 posi
Re: car wont start
Just because you recently filled up doesn't mean you don't have bad gas. There could be debris or older gas that just mixed up more when adding gas recently, or you could have pumped bad gas. I have pumped bad gas and diesel a few times and I have had starting issues because of it or issues with it pinging really bad.
Those codes are for the MAP/MAF and EST. All I can suggest since I don't know that much is to check the connection. If you have a maf then try to clean it using that cleaner for it then plug it back in. I have had several different cars with mafs go bad and they all started the problem was they would die immediately.
There could be an ignition module problem, but there are things to check before you get to that point. A bad ECM is also something to table until pretty much everything else has been exhausted.
Old 10-20-2015, 06:39 AM
SpaniardV6's Avatar
Re: car wont start
Don't know if its applicable, but was a problem with my older Fiat Punto Turbo 1.4i.
Car wont start, and mechanic said there can be too many things: coil, sparks, spark leak, fuel pump, ECU, etc.
When replace the MAF with one used, the car start so easy.
The MAF was putting so much fuel inside and the car can't start, the exhaust smell gas so much.
Trying to disconnect it.
tapwr
10-10-2015 08:53 AM
omnipotentgoku
10-06-2015 06:57 PM
Dskeezy16
10-06-2015 02:26 PM
86IROC112
10-04-2015 12:03 PM
Jlanz55
09-29-2015 08:55 AM
Quick Reply: car wont start
