camaro pics with Z06 wheels and wheel specs
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
I'm looking for camaro pics with Z06 wheels and wheel specs. What size spacers/adapters are you using and offsets on the wheels. Want to put them on my 91, but don't want the wheels to stick out past the fender lips.
Thanks!!
Thanks!!
1 Post
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
Re: camaro pics with Z06 wheels and wheel specs
saw this car over the weekend. didnt meet the owner though.
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
my camaro on 2 inch adapters
here are more pics of other cars
http://www.skulte.com/gallery/search...=adapter&go=Go!
go here for adapters, he will set you up. if you dont like the width, as long as its not custom, and you havent driven on it, you can send it back for a different size
it is a +54mm offset
Car: 1989 IROC
Axle/Gears: 3:23 Torsen 4th gen rear
18x9.5 with 2 inch spacers
I believe mine were 56 mm offset
Car: '85 Z28
yeah I saw that at Ocean City and couldnt get over to let him know about TGO and to bs about his car. Looked sick sitting there in the parking lot.
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Where did you guys get your spacers? I just picked up a set of C5 Z06s, 17s and 18s. Can't wait to get 'em on my Z28 - scared to see how much tires are gonna run me!
Car: 87 GTA
Car: 1991 Camaro RS
Car: 87 GTA
Get a 4th gen rear end (direct bolt-in) and you'll only need the spacers up front.
If you play your cards right, you can upgrade from drums (if you have them) to discs, to larger discs if you already have discs, better gears, and a posi , if you have an open gear rear end.
I have 2 1/4" spacers/adapters on the front with 17 x 9.5 +56mm offset ZR1's, with 18" wheels you can use 2" spacer/adapters. On the rear, I used 2" spacer/adapters for now, swapping in a posi/disk 4th gen rear so I can loose the spacer/adapters and upgrade to a posi/disk. Once I get the rear in, I'm gonna do C5 front brakes, which I can then use the 2" spacer/adapters on the front since the brakes will stick out about 1/4" father than stock.
I bought mine from www.skulte.com. I have a friend who bought some off ebay, and he had to hit them on with a rubber mallet, who knows how he's gonna get them off when he needs to? The skulte ones just slip on and off real easy.
Check out the links in my sig. for more pics.
Car: 91 Z28
Transmission: Automatic
Car: sold
I am just not a fan of those wheels on our cars, just don't seem to flow, now don't take that wrong there are some hot cars on this post, I just think there are better wheel combos out there for the third gen. Just my 2 cents sorry if you guys dont agree.
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
18x9.5 with a +56mm offset and 7.4" backspace, wrapped in Kumho Ecsta Supra 275/35ZR18's. Mounted with 2" Skulte adapters.
Car: 1992 Z28
Engine: Magnacharged heads cam lq4
Axle/Gears: strange s60 4.10
Here are some 17 x 9.5" wheels with Nexen N3000 tires 275/40r17. I have 2" spacers all the way around. They do not rub at all, it is extremely close though.
02 ss wheels, 2" spacers, tons of pics in sig
1 Post
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
i got 18x8.5 vette wheels with a 56mm offset, because they are an inch narrower than other vette wheels does this mean i should still run a 2 inch spacer?
Car: 92 RS Camaro Red RED LEATHER!
Engine: 305 Stock with chip
Axle/Gears: Stock
you should check out my pics of my C6 wheels i just put on. I used a 2in spacer all the way around and in the back I plasma cut 1/4in spacer to put on top of it. It made it just right fitting right under the fender
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
18" 9.5 all around, but after my C5 brake upgrade up front, I ended up with 1.7" Skulte spacers front and a 4th gen rear.
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
This thread died? I think these are frickin' sweet: C5 machined face dish. (Not my car, though )
And now I know what color I want to paint my car
Car: 1992 RS, 2000 Z28
Engine: LO3 with TPI Swap, LS1
Transmission: 700-R4, 4L60E
Axle/Gears: 3.42 with TruTrac LSD
I was just looking at these rims a few days ago! Now I know I definitely want them! These look GREAT on our cars! I believe they're only 600 for a set!
Car: 1991 Z28
Axle/Gears: 3.08
Car: 92 Camaro RS, 84 Recaro T/A
Engine: LS2, none in the TA at the moment
Transmission: T56, 700r4
Axle/Gears: 3.23 posi, G80 LSD
looking at a set of C5 Z06 rims (the black and chrome motorsport set from corvetteguys.com) 17x8.5 fronts (6.96 back space, 56mm offset), 18x10.5 rears (8.04 backspace, 58mm offset).
currently running a stock 3rd gen rear, but planning a 4th gen disc rear swap in the future, what size spacers should i get
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
wait, so where can i get spacers, that skulte place is out of buisness? any ideas?? searched on google, but not truly sure what im looking for...
Engine: V8 305 TPI
so the adapter doesnt matter, as long as its 2 inch thick right??
http://www.ezaccessory.com/Wheel_Ada...5450-5450f.htm
so those would work with 2 inch thick and 5 spoke.
4.5 to 4.5 wont work on a camaro... the camaro and corvette have 4.75 inch bolt pattern... these are the ones you'll need. http://www.ezaccessory.com/Wheel_Ada...5475-5475c.htm
#42
I bought a set of the ezaccessory.com hub-centric adapters, specifically labeled for corvette, camaro, from eBay.
since these are hub-centric, I measured the ID of the hub bore (the part that registers with the cars' axle flange):
2.767" 2.770" 2.770" 2.771"
I measure the axle flange hub diameters on my 90:
front: 2.781"
rear: 2.779" (9-bolt BW)
I just did one side of the car.
the ezaccessory adapter register that mates with the wheel hub bore measured at 2.765"/2.767".
on the C4 ZR1-style 17x9.5 wheels I bought, the hub bore is 2.796".
I think if I want to use these adapters, need to take them to a machine shop and get the bore ID increased 0.010" to 2.780". or is it normal to have a 10 thousandths interference fit? dunno...
and since I had the wheels off, BS on the stock IROC 16x8 rims is:
front: 4.5"
rear: 5-1/8"
just FWIW.
front: 2.781"
front: 4.5"
rear: 5-1/8"
just FWIW.
#43
Car: 1991 Rs Camaro
Engine: 5.3l h/c/i
Transmission: t56
here is my 91 rs, has 17x9.5 c6 zo6 deep lip wheels with 255/40/17 all the way around and 2inch adapters all the way around. you can fit wider tires if stock height but mine is lowerd and wont fit 275s
http://www.cardomain.com/ride/387853...oupe-2d/page-3
#45
You can fit 275's just fine even with your car lowered. There are guys running 285's and 295's with cars that are slammed farther down than yours without any inner fender well modifications.
on the rear.... 285's on a 10.5" wide rim with 56mm offset and a 2" adapter will fit even with sportline springs, believe it or not. Tight as hell but it'll fit.
You may even find some running as wide as 305, that'd be pretty brave though without any mods.
Your car looks great! make at least those rear tires 275's and I think you'll take its appearance to the next level!
Keep it clean man! looks great!
#46
Car: 1991 Rs Camaro
Engine: 5.3l h/c/i
Transmission: t56
#47
yup, i noticed that too, rear bump stop is pretty darn close. car in pic was jacked up on left side, so right-side tire is tilted towards top of wheel well, closer to bump stop.
I'm going to be trying some 275/40/17's on 9.5x17 rims on my 90, but trying to stay close to the stock backspacing of 5.125 inches for the rear. new wheels are 38mm offset (6.75" measured BS), so have some 41mm spacer/adapters on order to get it all right. net BS calculates out to 5.13".
I almost had a cow before learning that 9.5" advertised width rims are 10.5" overall width. I guess the width is measured on the inside of the bead seat, seat to seat. as opposed to plain old rim-edge to rim-edge. kinda always wondered about that.
#48
Car: 1991 Rs Camaro
Engine: 5.3l h/c/i
Transmission: t56
its just one side on mine that hits, the other has plenty of room, to me it looks like it was remounted on mine some how and just slashed my tire. and i didnt think about that at all when i got my wheels that they are 10.5 in wide over all! but oh well i got em to work! hopefully i will be running 275s again after i fix that one bump stop
#50
1 Post
Car: Too many cars
Doesnt the panhard bar affect the position of the rear end side to side. If your car is lowered you will need an adjustable panhard bar to fix it ryte?
