Anyone running C-6 corvette rims 18x9.5 19x10 ?
Old 01-22-2008, 08:30 PM
seaaldo's Avatar
I have a set off of 07' c-6, I talked to skulte and they said they will fit with no problem 2'' front 2.25 back spacers. Still curious if anyone has done it yet and is there any snags !
Old 01-22-2008, 10:40 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Re: Anyone running C-6 corvette rims 18x9.5 19x10 ?
FYI, they're only 8.5" front wheels.
I have them on my bird and that's a real good spacer size. It'll tuck in front just a hair more than I'd want though.
I rolled the rear lips a bit.
Old 01-23-2008, 10:32 PM
seaaldo's Avatar
Wow they look really good, thanks for the reply. I can't wait to put them on now. Did you go with 2.25 spacer in the rear and 2 in front ?
Old 01-23-2008, 10:37 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I have a 4thgen LT1 rear end and 1" spacer in the rear and a 2" in the front. Mind you, the track width on the front of mine is a hair wider because I've upgraded the brakes so I'd probably do 2.25" in the front.
Old 01-23-2008, 10:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
sick looking car Iansane
i'm curious as well if a 19x10 will fit in the rear. i'm not sure i'll like the staggered stance tho.
they say it can be done with a 2.25 inch spacer or so. i've seen those 19x10's listed as 68mm offset and 79mm offset. not sure which to go on, Skulte says 79mm offset and use a 2.25 inch spacer. 68 is more like 1.50-2 inch spacer
Old 01-24-2008, 09:37 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
I don't have C6's but I have some aftermarket wheels that were on a C6 on my car. 19x11 rears and 18x9.5 front. Fit fine with a little bfh in the rear.
Old 01-24-2008, 09:50 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Pics please? i'd love to see that setup
Old 01-24-2008, 10:14 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
I just have one pic, and it's kind of bad. I took it at night in the garage right after I put it on. I still need adjust my coilovers...needs to come down about 2". It looks like it sticks out in the pic, but it actually tucks nicely in the fenderwell. The vette used a 295/35/19 in the rear which is a bit too tall...so when they wear out I'll go with a 295/30/19.
Attached Thumbnails Anyone running C-6 corvette rims 18x9.5 19x10 ?-camaro-w-atp-wheels1.jpg
Old 01-24-2008, 09:06 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Same size as the ones on mine, I've kind of grown to like how it fills up the fenders.
Old 01-24-2008, 09:12 PM
seaaldo's Avatar
I can't wait to bolt them on I am going to go with the 2.25 in back and 2.0 in front. Looks really good.
Old 02-07-2008, 11:52 AM
AMH SCORPIO's Avatar
what size spacers?
so how dose it look? what size tires? any problems?
Old 02-07-2008, 12:02 PM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Originally Posted by AMH SCORPIO
what size spacers?
2" spacers in the front, 4th gen rear.
Frozer!!!
01-19-2024 04:55 PM
SiCkRs
Members Camaros
32
07-01-2018 04:53 AM
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
87iroctheo
Wheels and Tires
08-29-2015 09:44 PM
Exxon Limited
08-09-2015 08:13 PM
Quick Reply: Anyone running C-6 corvette rims 18x9.5 19x10 ?
