Tires and Rims 15"
Car: 89 RS
Engine: 305 TBI
Tires and Rims 15"
OK peeps, here is the question I have, and have read it many times in posts. Noone seems to have pics of a 3rd Gen, with 15" wheels and wide tires, exept with drag tires. Here is the problem.
I have just about finished with my 89 RS, wanting to order the wheels, but cant seem to find the correct back spacing. The wheels I have decided on are the Weld Draglites. Want at least 1" wider tire on the back, maybe 2. Gonna keep with the stock width on the front. What are the stock wheel size,and back spacing for the 15" RS wheels? I am also wanting to keep the hight of the tires about the same. With all this said I also want to keep them tucked under the fender wells. Suggestions are all considered and will love to see pics of these cars.
I am very old skool when it comes to the looks of my cars, so for this I am keepin with the 15 inch set up!!! So come on and let me see what everyone has !!!
1 Post
Car: projects.......
Re: Tires and Rims 15"
The factory 15" wheels are 15x7 - not sure on the backspace, pull out a tape measure. - For the rears, just look at the drag race set-ups. I believe 15x8 with a 4.5-5" backspace is fairly comon, 15x10 with a 5.5 bs.
Most guys shy away from 15's for praticallity. There's more/better tire availability with larger sizes and you can easily get better handling and a better ride quality. Plus the fact that 15's just seem to bring back the ****** head "turd"gen image.
1 Post
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
Shagwell speaketh much truth. It's getting hard to find top quality tires in 15". Seems odd that you've selected draglites but aren't interested in seeing drag car applications. Drag guys are about the only ones still shopping for 15s.
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
ive got prostars with 275/50s 15x8 4.5 in bs. www.cardomain.com/ride/2197664/9
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
im running 275-60-15s on centerline scorpion wheels 4.5 back space on 91 transam, see cardomain,later jimmy
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
https://webdisk.ucalgary.ca/~jmknopp...t,%20may06.jpg
I let my short-long blow in the breeze while i'm driving my reservation rocket!
Those are 275/60/R15's on 2nd gen Trans-am wheels from a '79 TA. 235/60/R15 on the front.
https://webdisk.ucalgary.ca/~jmknopp...0tires%202.jpg
I love the look myself.
Hotrodboba400
12-10-2019 07:07 PM
