greg weld wheels
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
greg weld wheels
so i found these bad boys on craiglist, brand new, and cheap!!
im going to pick them up tomorrow, thought id get some input from my friends on tgo.
what do you think?
http://kansascity.craigslist.org/pts/1320533934.html
oh, and i know i will have some work to get them to fit.
what do you think?
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: greg weld wheels
looks solid. The 6.5" of BS is ideal for wheel placement under the car, but you will have to do a LOT of work to get them to fit, a lot depending on what tire you use.
thanks!
yea, some cutting and fabbing is in order for sure. im running m/t et streets 26/11.50 15's. i just got the tran back in after installing a trans brake, took it for a spin and im ready for some good lookin wheels to handle some real tires.
