I know this has been covered, but...
Old 02-08-2010, 01:37 PM
bminus's Avatar
Car: 87 Firebird
Engine: Weiand 177 blown 406
Transmission: TH350
Axle/Gears: Stock 10 bolt/ 3.42s
I will be due for some tires this spring. My car will never see rain or snow, and it puts around to 450-500hp to the ground. It will see mostly street driving with the ocassional trip to the strip until I can afford to build a rear end worth a launch attempt. That said, will the simple BFG Radial T/A's in a 275/60R15 provide sufficient traction to avoid kicking it sideways at 60mph? Are there any other options for a 15x8 that will be drivable but not so sticky that it will grenade the poor 10 bolt? MT sportsman s/t's? Cooper cobra's? Goodyear eagles? I don't expect to get very much traction from 0 mph, but I would like to at least be able to feel a bit of power on an on-ramp without the rear end getting squirrely.
Old 02-08-2010, 08:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: I know this has been covered, but...
you seriously need more than a 15x8 if you are running a street tire.
Old 02-08-2010, 09:42 PM
bminus's Avatar
Car: 87 Firebird
Transmission: TH350
this is temporary. it won't be a street tire for long; just long enough to decide what I want to do for a rear end. right now the car has bald 235 bfg drag radials on it, and i'm afraid to upgrade to a bigger drag radial without a stronger rear end.
Old 02-09-2010, 09:55 PM
bminus's Avatar
Car: 87 Firebird
Transmission: TH350
nothing?
Old 02-09-2010, 10:10 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
arent firellis pretty decent?
Old 02-10-2010, 09:14 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
This is what I'm running on the rear .295/50r15s on a 8in. wheel. (wheels and tires are in my signature) I don't have the power you have but I really like the way these tires handle.Nice tire wear and decent traction.Here's a link=
http://www.gripston.com/products/hankook-ventus-h101
And heres a little something for a 10 bolt or whatever you need it for. Here's a link to LPW Racing that I found very helpful when looking for a support cover when installing my new Eaton posi, 28 spline axles,3.42 gears and cover. = http://www.lpwracing.com/p_capcovers.asp and here's the tube braces= http://www.lpwracing.com/p_axletubebrace.asp. Maybe not what your looking for but thought Id add it just in case. Its what I'm running for a cover. Really like it!!
Pac J
05-17-2020 10:44 AM
skinny z
10-05-2015 06:23 PM
1Aauto
Sponsored Vendors
10-05-2015 03:14 PM
82xCAMAROxZ28
09-27-2015 12:31 AM
Dragonsys
09-25-2015 03:51 PM
Quick Reply: I know this has been covered, but...
