17x9.5 all around. 5.5
Doug Glad has 17x9.5" Torque thrust IIs all around with 5.5" backspacing. He had the imfamous black '91 Z28. It eventually got a t-5, 383, charger, and nos!
how come he can have the same backspacing front and rear while our cars with 16s have different offsets? how does that work? do the rear or fronts stick out more in that case? can the 17s be rotated?
-Tas
'89 Formula WS-6
[soon to be Torch Red with black hood and headlights =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz | ICQ 82881207
-Tas
'89 Formula WS-6
Super GRK_Taz World
No they work okay, and look fine.
His are the same all around because it's the same size rim all around.
The 16" stock rims are different widths front to rear, hence the different backspacings.
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Ummm, no, the stock 16" rims don't have different widths. They do have different offsets and backspacing (2 related but different terms). The fronts have 0 offset (4" backspacing) while the rears have -16 mm offset (approx. 4 5/8" backspacing). The only way rims with 5.5" of backspacing will work on the front (or the rear for that size) is with spacers like those from Vette Brakes. Yes, if you get rims with the same backspacing for the front and rear wheels, you can rotate them with the tires mounted. Just get whatever size (offset/backspacing) works out for the fronts then order the same for the rears. The rears will stick out a little further, so you'll have to judge how you think they look...
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
Car: 91 Z28
Engine: 383-Carb
Transmission: TH400/3500 Stall
Re: 17x9.5 all around. 5.5" backspacing?
Are You Sure All Wheels tt II's 17x9.5 Wheels Have A 5.5 b/s?Cause Im About To Make An Order & Those Rims Are Special Order Custom Offset!
On Probation
Engine: several
Transmission: none
Axle/Gears: none
9.5 w/ 5.5 will work fine on the rear. Up front, you need the 1LE rotors, and may need to grind the outer tie-rod ends. Why not do 11s on the rear, with 7" BS? Then use 275/40s and 315/35s
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Front needs 5" backspacing or spacers to clear the TRE and in some cases, the strut body.
Eric-86sc
02-25-2016 09:02 PM
88SS6SPEED
11-11-2015 07:05 AM
