Backspace with 4th gen rear
Old 12-22-2010, 05:47 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Finally I've got a 12bolt rear on the way, from a 4th gen so now I have to get new wheels.......
How about rims....
Will 15x10 7,5" BS fit a thirdgen?
And what backspace should I get if I get 8" wide wheels...
Since 4,5"BS is common on our cars with 8"wheels then add 2" for a 4th gen rear....dont think there is any 8" with 6.5" BS
So yo guys wyth 4th gen rears what BS are you running, pictures are always nice. Will go for 15" in the rear with 275/65 Drag radials I think......
Old 01-08-2011, 04:36 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Backspace with 4th gen rear
i am running weld draglites with 15x10 with 7.5"bs. 1998 camaro rear. here is a video. you can see the wheels near the end of the vid. http://www.youtube.com/watch?v=08kcjhJ0EQY
Old 01-08-2011, 09:30 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
a straight edge and a tape measure works pretty well too. Why cant people think of this on their own?
Old 01-08-2011, 10:16 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
4th gen rears like 7-7.5" for 10" wheels. 5.5"-6" for 8" wide wheels. I run 15x8's at 5.5" bs. Fits good. It could be another 1/2 inch in tho.
Keep in mind, if you use LS1 rear brakes on the 4th gen rearend, most 15" wheels will not clear the brake calipers without a good deal of grinding on the caliper. I did that combined with a small 5/16" spacer to get the clearance I needed.
Old 02-25-2011, 08:08 PM
86CamaroNJ's Avatar
Car: 1986 Camaro Sport
Engine: 305 Carb
Transmission: 700r4 with mild shift kit
Axle/Gears: stock, looking to upgrade to 4.11
What size tire you running?
Old 02-25-2011, 09:20 PM
295 50 15
Old 01-12-2017, 08:56 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Transmission: TH-FO-HUNNIT
Hey guys, so i am getting ready to order my Weld wheels for radials. I am going with 275/50r15s, will be running a fourth gen rear, and am most likely going with a 15x9.33" wheel (Mickey Thompson suggests a max of 9.5" for a 275 tire but want to go as wide as possible). So if a 8.5" wide would like a 5.5" and a 10.5" would like 7.5", would a ~9.5" be best with a 6.5" backspacing to provide clearance in all the locations it is needed and still tuck in the fender moderately well? Thanks in advance and I hope to hear from some of you, Jeremy
1992rs/ss
05-19-2020 07:02 PM
Orr89RocZ
04-25-2016 08:28 AM
1992rs/ss
16
01-28-2016 09:58 PM
sweet_87_iroc
09-25-2015 10:01 PM
THABADGUY
Brakes
08-11-2015 03:43 AM
Quick Reply: Backspace with 4th gen rear
