are drag radials available for 16" IROCS?
Car: 1988 IROC-Z Camaro
Engine: 383ci SBC
Axle/Gears: 2.77 9 bolt borg warner
Stock 16" 1988 Iroc-z Wheels. Stock suspension, Stock G92(Borg 9 bolt, disc brake ect.) rear end.
Just want to get a set of BFG or hoosier drag tires to make some occasional passes at the local strip. they are going on 2 extra rims I have for the rear but don't know how much wider than the stock tire dimensions( 245/55/16 or something like that) without rubbing or going to a wider rim.
How wide are the factory rims btw?
Car: 1988 Camaro
Re: are drag radials available for 16" IROCS?
Here you go...
http://www.summitracing.com/search/d...9%2B4294827975
Engine: 383ci SBC
Thank brother, it never ceases to amaze me how long I can try and look for something on my own on summit and not get the same results as someone else. must have fat fingered the search criteria somewhere along the line.
Car: 1988 Camaro
lol yeah I been known to do that from time to time. Your welcome man.
Those should fit good.. The 275/55 M&H might be a little tight on the fit, but all the others will work great.
Engine: 383ci SBC
Street Lethal
04-30-2019 12:14 PM
mustangman65_79
08-11-2015 03:17 PM
