1990 rs stock to drag radial question
Car: 1990 camaro r/s
Engine: 350 bored .30
Transmission: turbo 400
Axle/Gears: stock
New at this subject but was wondering what is the widest I can go on a drag radial tire 15 inch for the back I don't care of they stick out a bit my rear end and everything is stock no mods done to the suspension I heard 295/50/15 would fit but don't know if that is the widest I can go or If I can go wider without any mods n don't know where I can get that size if that is the widest I can go
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: 1990 rs stock to drag radial question
Here's a few tires to chose from and should be able to order most of them from a tire shop. http://www.summitracing.com/search/d...5%2B4294897162
A 295/50r15 is a very wide tire. I made the mistake of putting a set on my car a long time ago. Lesion learned.
Any way here's what they looked like with the wrong BS and wheel width.
The top would rub the outside of the wheel well because they were out a inch.
What Im trying to say is I should have had at least a 9in. wide wheel with around 5.5 / 6 in BS. Even then they might not fit.
I now run the Mickey Thompson S/T's in 255/60r15 and that's the size that's prefect for my rear 8x15 wheels.
Here's a photo of the 295/50r15s on the rear then the 255/60r15 rears with 235/60r15s front.
Sanjay
08-12-2015 03:41 PM
