issue with removing tires
1 Post
Car: 2014 cruze and 1987 trans am
Engine: trans am=5.0
Transmission: auto
my t/a has the skinny 15 inch rims with pretty destroyed tires, if picked up a set of the 16 inch rims off of a WS6 car. the issue im having is that my rims/tires will not come off the rear, the front gave me some issues but with some pb blaster, a rubber mallet, and a few curses later they came off. is there something else about the rear i need to know? the lug nuts are off but the tire does not budge, ive noticed that there is a metal piece in the middle of the rim where the cap should cover, this was not an issue on the front but the rear i cant seem to remove the tire. and also would i need to get longer studs to account for the larger rim size?
the silver rims are the ones im removing, the gold rims are the replacements.
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: issue with removing tires
Put two lug nuts back on loosely, back up to the tire and give the side wall a all you can muster "mule kick". It may take a couple times (rotate kick), having been in the auto biz it worked for me many many times.
You shouldn't have to do anything with the lug studs.....
1 Post
Transmission: auto
Thanks for the help, ill give it a shot tomorrow. Stuck at work all day today.
1 Post
Transmission: auto
thanks for all the help, the tire finally came off after all of the above suggestions.
1992rs/ss
05-19-2020 07:02 PM
Fronzizzle
03-18-2019 08:29 PM
