Locking wheel nuts??
Car: 1984 Firebird S/E
Engine: 1985 2.8 MPFI
Transmission: 1985 T5 5 speed manual
Axle/Gears: 3.42/4.03
Just got ready to strip my rear axle on the donor car and it has locking wheel nuts fitted! The original plastic lug nut covers were fitted right over them so I'm wondering if they're a factory item or not? Any help would be great as I can't get them off as I don't have the key!
Car: 1988 Pontiac trans am
Re: Locking wheel nuts??
Use a socket that just barely fits over the lock and hit the socket with a hammer, then use a breaker of some sort, that should get it off.
Tried that already. Split three sockets. They look like hardened steel lock nuts so trying that won't work.
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Use better sockets?
or you can buy the removal tool from most auto parts stores. Looks like a socket bit has teeth inside. Hammer on and go.
OK, found out it is factory, has the RPO cod for it. Anyway, I don't have the key so I'll be buying the tool to remove it and cracking it off!
Thanks for the help guys!
Car: 1988 Camaro
I have used vise grips and hammer before to get aftermarket locks off.
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: 3:73
Omega
10-01-2015 02:20 PM
